Is it possible to make a 3 wire iacv work with a obd1- p28? If so, how?
Old Sep 24, 2006 | 10:36 AM
RACEPAK's Avatar
Default Is it possible to make a 3 wire iacv work with a obd1- p28? If so, how?
and how...
thanks.
Old Sep 24, 2006 | 11:33 AM
Relic1's Avatar
no.
the way it's controlled is different.
You may be able to put something togethr if you're able to design and build electronic circuits, but it will never be as good nor as cheap as simply converting to a two wire.
Old Sep 24, 2006 | 11:52 AM
RACEPAK's Avatar
Default Re: (Relic1)
ok.
so i just read what you wrote in another thread.
and tell me if i'm right.
the 2 wires are yel\blk and blk blu.
the yel/blk should be tapd to one of the yel/blk wires on the driver's strut tower?
and the blk\blu to the ecu?
thanks
Old Sep 24, 2006 | 02:45 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (RACEPAK)
Old Sep 24, 2006 | 02:57 PM
RACEPAK's Avatar
Default Re: (HondaPartsHero)
my ecu is nothing like that.
i got only 2 iacv pins on my ecu. iacv (-) and iacv (+). but my currend sensor is 3 wiers.
Old Sep 24, 2006 | 03:02 PM
Relic1's Avatar
your ex-ECU plugs should look like that. (OBD2a)
once you have done this conversion the OBD2-->OBD1 harness wil work perfectly.
Old Sep 24, 2006 | 03:11 PM
RACEPAK's Avatar
ok.. my car is a edm civic 1.4L d14a4. this ecu is abit wierd,
its not like any other obd2 ecu.
here are the pinouts if you want to have a look:
http://www.turbod16.com/viewtopic.php?t=8133
Old Sep 24, 2006 | 03:14 PM
Relic1's Avatar
pretty red Xs
Old Sep 24, 2006 | 03:19 PM
RACEPAK's Avatar
fixed..... well... kinda
Old Sep 24, 2006 | 08:44 PM
Relic1's Avatar
a bit weird? that would be an understatement.
Which of the wires do you have running to the P28's A12?
the other side needs to run to the yel/blk wires that contain ign power from the main relay. (driver's shock tower)
that is assuming that the wiring is close to that on the USDM cars.
Old Sep 25, 2006 | 01:17 PM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">a bit weird? that would be an understatement.
the wire i was planing to hook up to a12 on the p28 was the a17 on my ecu (rad fan control). but on the diagram that you gave me its RFC...whats RFC ? :s
Old Sep 25, 2006 | 02:01 PM
Relic1's Avatar
I'm guessing that it stands for... Radiator Fan Control
why use the radiator fan control wire? the ECU needs that to turn on the radiator fan if the coolant gets too hot. (or is your car not wired for that kind of control, it should be)
You have two wires from the ECU to the AICV all ready, use one of them.
Old Sep 26, 2006 | 07:22 AM
RACEPAK's Avatar
stupid me:S
You have two wires from the ECU to the AICV all ready, use one of them.</TD></TR></TABLE>
which one do you assume that will work? and what should i do with the other one (that i dont need)?
thanks
Old Sep 26, 2006 | 09:43 AM
Relic1's Avatar
either will work since you're moving the pins around anyway.
The other wire will simply do nothing. Unles you need a wire for something else.
Old Oct 9, 2018 | 10:52 PM
JDils926's Avatar
Default re: Is it possible to make a 3 wire iacv work with a obd1- p28? If so, how?
If I'm using a p28 and jumper harness do I still need to re-pin wires on the plug that goes into the new jumper harness? So basically can I plug my harness into jumper harness then plug in my p28 and be good?
Old Oct 10, 2018 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
As long as you have converted the three wire IACV to a two wire IACV on the original OBD-2 style plugs... that means removing the orange wire and moving the black/blue wire to the alternate 2-wire location. Then, when you plug in the adapter harness and your P28 ECU, the IACV should function correctly.
Old Oct 11, 2018 | 12:47 AM
JDils926's Avatar
Ok cool thank you, but ok so I'm gonna be a pain in the *** because I got 3 people telling me **** and it's getting annoying so I'm gonna lay it all out on what I got going on so I would appreciate any help please, ok so I have a 1997 ek hatch I'm running a d16y7 block with d16y8 head with y8 mani y8 tb and a p28 auto converted to manual. Wich engine harness will work the best? Should I use y8 engine harness with p28 ecu? Or do I run the y7 harness do the iac conversion then run jumper harness to my p28 ecu
Old Oct 11, 2018 | 08:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If it were me, I would use the engine harness that CAME in your 1997 EK hatch and modify all necessary plugs to fit your mini-frank engine mess. This engine harness will have a 3 wire IACV, so you will have to convert the wiring at the ECU plugs as well as add the VTEC wiring. Lastly, you will need an OBD-2A -> OBD-1 adapter harness so that you can plug in your P28
Old Oct 13, 2018 | 06:17 PM
JDils926's Avatar
Ok cool thank you, so is there any other plugs I need to change? This all on my buddys car and this is the first d series I've done so sorry if it seems like I'm asking stupid questions, so we got rid of the orange wire and moved the black/blue and added the vtec wires, my only other question is about the plugs, will all the d16y7 plugs all plug into the 16y8 plugs on the intake mani, like the map sensor and tps sensor are the same and seems like there are other plugs that go to nothing? So I'm getting confused, basically will his stock harness work for it all other then switching the iac and vtec wires. Do I need to extend some wires? Do I need to swap some of the Grey plugs on y7 harness to plug into y8 map senor and tps sensor and whatnot?
Old Oct 13, 2018 | 06:29 PM
JDils926's Avatar
That and the plugs that go into the ecu like the blue one says it's the a plug, the Grey one says it's the b plug but online all the plugs say the Grey one is the a plug and b is blue plug, and since I'm running the p28 do I still need to run a knock sensor? Do I still have to splice and cut wires on the blue plug? Or can I juss re-pin the wires on the Grey plug for iac?
Old Oct 13, 2018 | 08:07 PM
JDils926's Avatar
So what are the 3 wires on the bottom? My harness does not have those? And it says A plug, mine says b plug and my harness is 96-98 obd2a, is obd2a different then obd2? This is what im getting confused on ill putt pics of my plugs on here
Jeffrey Bongers
11
Jan 7, 2017 01:46 PM
jackiewogn518
Engine Management and Tuning
Feb 27, 2010 10:54 PM
my_hidden_romance
Feb 8, 2009 11:53 PM
u2civic1
Aug 1, 2003 01:11 PM
