Need help on my OBD1 swap. (mix n match)
Old Sep 24, 2006 | 10:16 AM
RACEPAK's Avatar
Default Need help on my OBD1 swap. (mix n match)
hello everyone.
i'm doing a obd1 P28 swap insted my wierd euro obd-2 P3Y.
i have most of the wires covered up. but i still have some wires that i dont know where should they go.
my ecu:
vcc1 and vcc2 (sensor voltage)
ig r (ignition pulse return signal)
ig pls (ignition pulse)
iacv n (negative side)
iacv p (positive side)
the p28:
a9- iacv iac valve blu\blk about 10v koeo on warm engine
a10-intake control solenoid, battery voltage with koeo
a21-ICM yel\green ignition control module (icm) output signal about 10v with koeo
a22- *pre sender* ignitor same as a21
d19-reference voltage red/wht, about 5v koeo
d20-reference voltage yel/wht, about 5v koeo
i'm not mentioning the vtec wires, distributor wires and o2 heater that i need to deal with cause this is another story.
but anyway.
these are the ones that i need to deal with:
b11-b16, d6 a4, and a6.
thanks for any help.
vtecpros
Mar 12, 2010 12:38 AM
Ghett0_ed
Feb 10, 2009 07:59 PM
1990EFHATCH
Apr 4, 2008 03:16 PM
d16t-hatch
Feb 21, 2007 10:59 PM
