launching wheelhop ect
Old Sep 24, 2006 | 10:01 AM
JayDMteg's Avatar
Default launching wheelhop ect
ok i drive a 92 integra i got a lsv motor NA around 200 wheel hp 145 trq im having problems leaving the line
set up
skunk 2 coilovers tockio blues
all new busshings front camber kit
lsd tranny ys1 jdm
full race traction bars
alligned
upper strut bar
thats it up front
still have 1st gear wheel hop (BAD) and spins no matter what at 6500 unless i pedal
so im just worried about the hop i figured the traction bars would elimnate that
if i can get rid of that hop my spinning through first may be helped alot what is left to do
i have slight play in RF upper ball joint??? its minimal could that cause car shaking wheel hop or maybe i need better struts??? any help on this whould be great o on kumo 205 50 15s but have had 14s and 16s same problem
Old Sep 24, 2006 | 03:45 PM
JayDMteg's Avatar
Default Re: launching wheelhop ect (JayDMteg)
help me !!!!
Old Sep 25, 2006 | 04:44 AM
boostedcivicsir's Avatar
Mr. Badwrench
good engine mounts?
Old Sep 25, 2006 | 04:53 AM
RTW DC2R's Avatar
dont traction bars have to be adjusted for them to work correctly? otherwise Id say maybe motor mounts are needed in your case as well. what clutch are you running?
Old Sep 25, 2006 | 11:40 AM
Mista Bone's Avatar
D Tranny Guru
slicks, no more problems......
what tire psi you running? Need to drop it
Old Sep 25, 2006 | 04:24 PM
JayDMteg's Avatar
Default Re: (Mista Bone)
monts are good all es inserts or filled with urathane thats fine running 28 psi and the bars were set to spec allthough i have tried caster + - with no luck
how bout a good set of drag radials???
Old Sep 25, 2006 | 04:25 PM
JayDMteg's Avatar
Default Re: (JayDMteg)
could my clutch cause hop its a exeddy full face
Old Sep 26, 2006 | 12:16 AM
Mista Bone's Avatar
D Tranny Guru
Why you need suck a clutch when a stocker would be fine?
Somthing HAS to slip when launching. Either the clutch slips, wheels spin, or you bog the launch.
Wheelhop is like clutch chatter, either too much clutch or not enough HP.
Softer clutch, like a stocker
Old Sep 26, 2006 | 09:28 AM
one slow coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">slicks, no more problems......
Old Sep 26, 2006 | 06:18 PM
WFboostinEK's Avatar
Slicks are the way to go
Old Sep 26, 2006 | 08:07 PM
JayDMteg's Avatar
Default Re: (WFboostinEK)
i think i will try that i just wonder if drag radials will do the trick
Old Sep 26, 2006 | 08:39 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDMteg &raquo;</TD></TR><TR><TD CLASS="quote">monts are good all es inserts or filled with urathane thats fine running 28 psi and the bars were set to spec allthough i have tried caster + - with no luck
</TD></TR></TABLE> try lower airpressure ,on my anzies anything over 15psi id get bad wheel hop, but there real stiff sidewalled and i run about 7psi, but if you plan on going to the track alot Get some Slicks, a world of differnce
Old Sep 26, 2006 | 09:05 PM
Default Re: (OBRJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDMteg &raquo;</TD></TR><TR><TD CLASS="quote">i think i will try that i just wonder if drag radials will do the trick</TD></TR></TABLE>
not soo much... radials still cause alittle bit of hop. and why not spend the extra few $ to get some slicks and much better 60's
Old Sep 26, 2006 | 10:31 PM
Mista Bone's Avatar
D Tranny Guru
slicks are cheaper than drag radials
Old Sep 27, 2006 | 04:08 PM
JayDMteg's Avatar
yeah now what size slick for a factory 14in honda wheel that wont be larger taller than stock?? wider is fine ??
really lower than 15 psi that sounds way to low but maybe i def will try lowing more
OO and i changed that balljoint and still hops and struts are still very strong so i guess its gonna need a set of slicks... HELP ON CHOOSING A GOOD SET ?
Old Sep 28, 2006 | 08:31 AM
4gencivicef9's Avatar
lenso slick site ......is good ... its like 500 for a brand new set with rims
Old Sep 28, 2006 | 01:40 PM
JayDMteg's Avatar
Default Re: (4gencivicef9)
good looks hey whats a good size to get?
Old Sep 29, 2006 | 06:23 AM
usaully I always see honda guys at the track with 23" slicks, they get them wide and not tall...
http://www.exospeed.com- great site if looking for a set of slicks they have other stuff there to..built motors , sleeving serivces, check it out...
gosu08
Aug 20, 2007 01:40 PM
Blacklabel182
Apr 2, 2007 06:50 PM
young noob
Suspension & Brakes
Nov 16, 2006 01:00 PM
RTW DC2R
Apr 23, 2003 12:30 PM
b18c51032000
Apr 18, 2003 03:55 PM
