OBD1 to OBD0 conversion
Old Sep 24, 2006 | 10:00 AM
d16T3project's Avatar
Default OBD1 to OBD0 conversion
ok i have a 93 civic coupe (OBD1) and i just picked up A B18a1 out of a 90 integra from pick n pull for $165 got a hell of a deal... but its OBD0 im sure this isnt hard but i was just lookin for some sort of a write up or some one that knew how to convert OBD1 to OBD0 thanks and let me know
Old Sep 24, 2006 | 11:15 AM
sauceja's Avatar
Default Re: OBD1 to OBD0 conversion (d16T3project)
Stay obd1. Get an obd1 dizzy or replug yours. Not sure about those mounts but the alternators are the same obd0/obd1 they didn't change until obd2.
My obd0 b16 plugged right up to a 93 civic si harness just had to extend the O2 wiring and reroute the IAT sensor wiring.
You should be good to go. If nothing else you can reuse your rear mount and tranny mount. You will need the rear bracket from new engine and drivers side mount from your engine or a 94-01 teg. the front torque mounts you can use any b-series if your engine takes them.
hope this helps.
Old Sep 24, 2006 | 12:13 PM
Default Re: OBD1 to OBD0 conversion (sauceja)
yeah thanks man so i can plug an OBD1 dizzy to the OBD0... and did you say my single cam dizzy would work?
Old Sep 24, 2006 | 08:51 PM
sauceja's Avatar
Doubt single dizzy will work and I said you may have to replug your dizzy plugs. In your case it may be easier to get an obd1 ls dizzy. At least get the bare housing with the wires and gut yours over to the obd1 dizzy.
Jul 4, 2009 09:18 PM
hybridej7
Dec 20, 2004 07:15 AM
skud_dusty
13
Apr 25, 2003 11:51 PM
