CD_5 in need of help
Old Sep 24, 2006 | 01:07 AM
DALAZ_68's Avatar
Default CD_5 in need of help
ok so my car ( 97 accord LX F22b2) is just bleh rite now
1. my window are slow , sometimes they totally stop
2.my rite front passenger side door lock makes the loudest fucken annoying sound when i lock it with my driver side, passenger master lock, but not wen its pushed in manually
3.if i try to use my lighter port for my car charger, my stereo goes out and blows my fuse
4. my 3 and 4 spark plugs are flooded with oil, i had my mechanic remove the cover, clean throughly and resela with new gasket and washers, checked about a month later, still happeneing, redid the whole proccess, checked a week later same thing
5. when i shift from P to R or D4 the car kinda i dunno'' hops'' or jolts
6. in the morning when i first warm up my car, and try to leave quietly, my car makes loud as hell squeak noise, ( i think belt related) and i dunno wut to do
so yeah being second owner of a car sucks when the first owner didnt take car of the car
if needed illl provide video for u to hear any noises i tried to described
please help
Old Sep 24, 2006 | 01:34 AM
importfanatic17's Avatar
Default Re: CD_5 in need of help (DALAZ_68)
1) All 5th gens are like this. You can get the motors replaced, but it happens frequently.
2) Check the wiring leading to the lock, perhaps it is worn out? ---total guess
3) By a new lighter port (they are relatively cheap)
4) I totally forgot what oil in the spark plugs means, search, the answer is readily available.
5) I have no clue...gearbox maybe?
6) Check all belts, they might need to be replaced or tightened/loosened.
These are just my ideas, I am by far not perfect, so enlist in more help as well.
Old Sep 24, 2006 | 07:25 AM
CBL9's Avatar
The oil in plug wells is common too. It happens on 90-97 frequently. The valve cover has little round seals that go around where the VC and the Head meet flush. If those are shifted then oil leaks down into the Head and collects in the spark plug wells. The one place in teh head you do not want oil
Wait until your car has no to minimal acceleration and you need the egr ports cleaned out, that will be one more reason to hate your car
Old Sep 24, 2006 | 04:10 PM
Honda_Accord's Avatar
Default Re: CD_5 in need of help (importfanatic17)
for the 4th question with your oil in your spark plug. Go here
http://www.cb7tuner.com/vbb/sh...seals
its b.c the seals under the rocker arms are bad. Same thing happend to me, so after i replaced them, no more oil
Old Sep 25, 2006 | 10:55 AM
DALAZ_68's Avatar
thanks guys iv fixed the steeo situatio, it was the cover for the wire came loose, wen it touched the rim of the metal around it, it would blow the fuse, one down.
as for the recommended rocker arm diss, i think that might b it, since i replace the other covers besides that one due to time limit i had
anything else would b appreciated thank u
majesticoj
May 22, 2017 11:12 AM
ksettles619
Apr 27, 2012 11:49 PM
d1nki
Jan 25, 2009 09:50 PM
Ajonie5
Oct 13, 2007 01:23 AM
whagkangmakulet
Dec 15, 2006 08:21 AM
