Moroso 20911 Pan, Does it require modifying the engine/flywheel cover brace?
It says stock configuration and no xtra kickout, would it still interfere with the ITR stiffner/flywheel cover brace thing?
http://www.moroso.com/catalog/...11295
anyone know?
anyone know?
the oem flywheel cover would require some mod. it is hard to see in picture, but you must trim the corners of the cover.
it takes 2 min with a grinder
http://forum.club-honda.org/at...44246
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRnorway »</TD></TR><TR><TD CLASS="quote">the oem flywheel cover would require some mod. it is hard to see in picture, but you must trim the corners of the cover.
can't see the link, registered and still can't access it.
so even the 20911 requires trimming? i thought only the 20910 or 20909 required trimming since it has a kickout?
