Axle snapped!
Old Sep 23, 2006 | 10:22 PM
R.Kelley's Avatar
Default some carnage
well i just finished breaking in my 2ms Action clutch im 98 hatch(gsr/si tranny) and i bang second gear and this is what happens
Old Sep 23, 2006 | 10:35 PM
Syndacate's Avatar
Brutal **** dude....well at least your problem is obvious...
Old Sep 23, 2006 | 10:42 PM
thehatchninja's Avatar
wow. Yeah, no annoying diagnosis troubles.
Old Sep 23, 2006 | 10:55 PM
Miracle's Avatar
Default Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">wow. Yeah, no annoying diagnosis troubles. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Brutal **** dude....well at least your problem is obvious...</TD></TR></TABLE>
True. That sucks man. Upgraded clutch &gt; stock CV's.
Old Sep 23, 2006 | 11:54 PM
sol2hatch's Avatar
Default Re: some carnage (R.Kelley)
O, SNAP!!! lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.Kelley &raquo;</TD></TR><TR><TD CLASS="quote">well i just finished breaking in my 2ms Action clutch im 98 hatch(gsr/si tranny) and i bang second gear and this is what happens
What kind of axles should i buy to avoid this situation again??
There, I turned this non-tech post into a tech one, just for you,
Old Sep 24, 2006 | 12:09 AM
nighttrain33's Avatar
Sucks! But..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">at least your problem is obvious...</TD></TR></TABLE>
lol
-Shane
Old Sep 24, 2006 | 04:33 AM
JShull's Avatar
Wow....I think it got tired..haha. An easy fix for sure. Less than an hour hopefully.
Old Sep 24, 2006 | 07:12 AM
TurboTagTeam's Avatar
Default Re: (JShull)
It's Gator time
Old Sep 24, 2006 | 08:05 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (TurboTagTeam)
haha gota love when an axle snaps..
Old Sep 24, 2006 | 08:07 AM
schardbody's Avatar
that axle didnt snap from power and traction, it snapped from rust. the rubber harmonic dampner made the rust build there even more than the rest of your car, therefore it was WEAK.
Old Sep 24, 2006 | 08:42 AM
R.Kelley's Avatar
it broke nearly an inch from the dampner....edit im sorry im a ******** it did break on the rubber dampner...
Modified by R.Kelley at 2:26 PM 9/24/2006
Old Sep 24, 2006 | 11:16 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (R.Kelley)
thats what you get for shifting like an angry gorilla
Old Sep 24, 2006 | 12:29 PM
A.E Motoring's Avatar
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">thats what you get for shifting like an angry gorilla</TD></TR></TABLE>
LMAO
Old Sep 25, 2006 | 02:01 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.Kelley &raquo;</TD></TR><TR><TD CLASS="quote">it broke nearly an inch from the dampner....edit im sorry im a ******** it did break on the rubber dampner...
Modified by R.Kelley at 2:26 PM 9/24/2006</TD></TR></TABLE>
believe it or not: our cars making NEAR stock to stock power (any motor) wont snap an axle w/out huge slicks. street tires will give way before an axle shaft snaps unless you have other problems, thats how i figured it was rust related.
Old Sep 26, 2006 | 04:45 AM
92_VX_EG's Avatar
Default Re: (schardbody)
Wow I need to post the pick of my snapped axle and the axle piece that I pulled out of my tranny. I have an obd-1 LS swap(ls tranny) with intake, header, exhaust, and a 6 puck. I broke my napa axle after I had the motor in for 3 weeks. It broke off flush with the tranny, I had to drill/tap the piece, put a bolt in it, and yank it out... It took me 2 hours to get it out. And I was on street tires taking off at only 4k.
Old Sep 26, 2006 | 09:29 AM
killakoupe's Avatar
From: San Diego to Palm Springs Runnin Things, CA, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">O, SNAP!!! lol
There, I turned this non-tech post into a tech one, just for you, </TD></TR></TABLE>
haha
goodluck man
Old Sep 26, 2006 | 02:50 PM
schardbody's Avatar
Default Re: (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG &raquo;</TD></TR><TR><TD CLASS="quote">Wow I need to post the pick of my snapped axle and the axle piece that I pulled out of my tranny. I have an obd-1 LS swap(ls tranny) with intake, header, exhaust, and a 6 puck. I broke my napa axle after I had the motor in for 3 weeks. It broke off flush with the tranny, I had to drill/tap the piece, put a bolt in it, and yank it out... It took me 2 hours to get it out. And I was on street tires taking off at only 4k.</TD></TR></TABLE>
i garentee you it had nothing to do w/ the power and traction. defective axle most likely. how many have you snapped since then???
Old Sep 26, 2006 | 05:21 PM
R.Kelley's Avatar
its the second one that i broke the first just popped the joint but that was the old tranny and cluch and tires
its a obd1 gsr, Blox IM, DC header, no cat, rsr exmag
the tranny is a 99-00 SI rebuilt 2k ago with carbon coated syncros, 8lb action flywheel, and action MS2 six puck put to the ground on new falken RT-615s
Old Sep 27, 2006 | 02:42 PM
jdmeg9's Avatar
i have had my b16 swap for 6 years and didn't have a prob til i swapped over to FI and supercharged it broke both axles in a week. had to toe it the first time cause i have lsd don't use reman axles go to Napa and tell them you want brand new ones. they cost like 20 dollars more and they are the ones the dealer uses when they don't have one at their shop. haven't broken one since then
Old Sep 27, 2006 | 04:19 PM
kameleon23's Avatar
Default Re: (Syndacate)
True...gotta be a wheel bearing
Old Sep 29, 2006 | 04:44 PM
92_VX_EG's Avatar
Default Re: (kameleon23)
Yeah mine was definately a defective axle. If I knew how to post up a picture of it I would. I'm having more axle problems with mine. I made a post but nobody has replied with any answers.
Old Sep 29, 2006 | 08:20 PM
thahuhstunna's Avatar
siiiick
skata89
Mar 24, 2006 01:10 PM
Markb16a
14
Oct 16, 2005 08:22 PM
Ponyboy
Acura NSX
16
Sep 20, 2005 08:03 AM
Airmax55555
Dec 29, 2003 01:35 AM
austrian type-R
Sep 19, 2003 12:56 PM
