2 trannys changed, 4 pairs of seloniods and 2 tcu and same d4 light :( on my 93 accord
Old Sep 23, 2006 | 08:48 PM
primemal's Avatar
Default 2 trannys changed, 4 pairs of seloniods and 2 tcu and same d4 light :( on my 93 accord
2 trannys changed, 4 pairs of seloniods and 2 tcu and same d4 light on my 93 accord.The codes i get is 7,and 8 which on this webpage (http://techauto.te.funpic.org/transmission.php ) says its solenoids,i have change soleniods like babies change diapers and still same thing car comes out real slow and only way to drive is chage gears manually and even then sometimes comes out slow
ps i have also change the mainrelay another things is doing now is sometimes it wont start,it atcs like its gona start and then dies
Old Sep 24, 2006 | 05:46 AM
Ross 2.0's Avatar
In a Junkyard near you.
Are you using honda brand parts? and is the same shop doing the work every time?
Something is really fishy here.
Old Sep 24, 2006 | 10:44 AM
Chiovnidca's Avatar
Default Re: 2 trannys changed, 4 pairs of seloniods and 2 tcu and same d4 light :( on my 93 accord (primemal
Have you checked the wireing?
Old Sep 24, 2006 | 01:17 PM
primemal's Avatar
yes im using honda parts mostly rebuilt.i have not checked the wiring,the only wires i check where the ones conected to the solenoids and it had a bit of rust so i clean it as best as i could.How come my tcu wont reset thoe whats the correct way to reset disconecting the negative from batery is not doing it the code is givng me is 7and second one is 8
Old Sep 24, 2006 | 01:20 PM
Chiovnidca's Avatar
Default Re: (primemal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primemal &raquo;</TD></TR><TR><TD CLASS="quote">.i have not checked the wiring,the only wires i check where the ones conected to the solenoids and it had a bit of rust so i clean it as best as i could.</TD></TR></TABLE>
Corroded connector pins could be the problem. I've seen it a few times.
CA93accord
Aug 31, 2015 05:18 PM
Azteck
Feb 26, 2011 04:21 AM
primemal
Aug 7, 2006 09:09 AM
Sia
Oct 18, 2004 10:20 AM
