2nd gear lagging
Old Sep 23, 2006 | 05:29 PM
uLikeMyPreludeSi's Avatar
Default 2nd gear lagging
hi guys
i just put a d15 in a 93 hb and while driving the car laggs just in 2nd gear from 3500 rpm to about 42. i think its maybe gas?
Old Sep 23, 2006 | 05:40 PM
jdmjaser's Avatar
Default Re: 2nd gear lagging (uLikeMyPreludeSi)
fuel...coil...maybe?? dont really know
Old Sep 23, 2006 | 07:13 PM
Default Re: 2nd gear lagging (jdmjaser)
thanks jdm. anyone else??
Old Sep 23, 2006 | 07:21 PM
thisisntjared's Avatar
so it doesnt do this in 1st or 3rd gear?? it could be your o2 sensor (or o2 sensor wiring)
when my wires were loose it felt like the car fell on its face until it got in the higher rpms.
Old Sep 23, 2006 | 07:42 PM
Default Re: (thisisntjared)
all other gears are fine just 2nd. if o2 it should do it in all gears right? thanks for the help. maybe i need to get off my a$$ and take the gsr out one hatch and put it in. gosh thats going to be a lot of work and i just put the d15 in too.
Old Sep 23, 2006 | 08:23 PM
Jhonny Ricer's Avatar
Default Re: (uLikeMyPreludeSi)
maybe you put third gear in seconds place by mistake lol j/p if it doesnt drag in any other gear id count fuel out cause if your fuel wwas bad it would bog entirely through any gear i think it might have something to do with your tranny
Old Sep 24, 2006 | 02:44 PM
with the o2 wires loose my car would never bog in 1st or 3rd. mostly 2nd and 5th. the wires were loose, not disconnected. but your situation could be completely different. do you think it might be tranny related??
Old Sep 24, 2006 | 05:33 PM
bump
Old Sep 25, 2006 | 06:35 PM
im not saying it is the tranny im not a certified maechanic so im not going 5to place money on it could be the 02 check it out if not and it isnt something going on with your gears i dont know what to tell you
Old Sep 26, 2006 | 06:58 AM
Default Re: (Jhonny Ricer)
see thats what i was thinking too. if there is something wrong with the tranny... there is NO advice i can give. ive never heard of power loss in one gear being tranny related, usually its a gear gone notchy or grinding, or doesnt exist, sometimes a specific gear might get loud, but ive never heard of power loss in a specific gear being the fault of the tranny.
i speculate that its something on the fuel ignition side just because the engine is doing different things in each gear as far as load, o2 readings, rate of change in rpm, etc.
i am not a certified mechanic either, i am just saying what my most recent problem was. the actual problem could be from a list of possibilities. i was just offering a simple thing to check. in my instance, 3 of the o2 wires were just loose so i was getting readings, just bad ones.
Old Sep 26, 2006 | 09:19 PM
thanks guys for the help and imma check the o2 sensor in the morning and ill let you guys know how that goes
Old Sep 26, 2006 | 09:21 PM
FalkenSiR's Avatar
ignition wires bad? seen it happen, always at a certain rpm, with the right throttle, sometimes in one gear, sometimes more...
Old Sep 27, 2006 | 05:13 AM
check some of the other wires too around other random sensors that deal with fueling. it could be coming from other places as well.
Clermont Bill
Acura TL, RL & ZDX
Jan 28, 2018 09:51 AM
taimysho0
Honda Civic (2006 - 2015)
99
May 11, 2010 03:34 PM
jdm_DC2R
Mar 21, 2006 08:37 AM
Thirty-Nine
Oct 18, 2002 11:11 AM
