Well.. Shit.. Turbo = no? yes? *picture of problem*
Old Sep 23, 2006 | 04:04 PM
TylerC161's Avatar
Default Well.. ****.. Turbo = no? yes? *picture of problem*
If you cant tell from the picture, not only is the turbo hitting the radiator, but the manifold is not even all the way on the head, if it were, i'd hit even more.. on top of that, that big bracket you see is where my alternator should go..
what would you all reccomend?
1. Flip the turbo around and have another custom downpipe made, with hopefully enough room
2. get a new manifold, with a different turbo mounting location (like a top mount)
3. something else.
Old Sep 23, 2006 | 04:09 PM
b18tegg's Avatar
Default Re: Well.. ****.. Turbo = no? yes? *picture of problem* (TylerC161)
I think you answerd your own question
Old Sep 23, 2006 | 04:18 PM
TylerC161's Avatar
Do they make half size radiators for preludes?
Old Sep 23, 2006 | 04:21 PM
SteveoBA8's Avatar
Default Re: (TylerC161)
I think Hawkze made a write up for a civic rad, search around for it. I seen them before. The civic rad will be where your passenger side fan is. here somes pics https://honda-tech.com/zerothread?id=1106207
shutta's Avatar
I woudl have mocked it all up before I have a custom dp made.. but since you are already did, i think you'll probably have to again because there is no way that thing is moving out of the alternators way. mock up where you want everything to be, chekc out the prelude pics section to see what other people are doing, and maybe get a civic radiator
Old Sep 23, 2006 | 04:22 PM
shutta's Avatar
get a bigger shot of the engine bay so we can see the big picture how things are looking under the hood
Old Sep 23, 2006 | 04:48 PM
TylerC161's Avatar
Default Re: (shutta)
http://img158.imageshack.us/im...9.jpg
http://img158.imageshack.us/im...0.jpg
http://img206.imageshack.us/im...2.jpg
Old Sep 23, 2006 | 05:21 PM
axlline's Avatar
I bet it would fit in here
Old Sep 23, 2006 | 05:30 PM
TylerC161's Avatar
duuuude that is CLLEEEAANNNNNN
wow..
where did all your wiring go? mine is ALL over. jesus
99LudeDude's Avatar
I'm willing to bet you have the turbo incorrectly mounted on the manifold. From the looks of your pic, you need to flip it around. Also that may be the wrong mani for your car. You might want to double check with the manufacturer of the manifold.
Old Sep 23, 2006 | 06:03 PM
fastludeh22's Avatar
Default Re: (99LudeDude)
did you have the manifold made to ur ar by somone locally, or did you buy the dp for your car w/that mani? if its the 2nd one, then you have the turbo turned around. the turbine side needs facing the alternator. there is bolts on the side of the compressor and turbine so u can adjust everything, dont take these bolts out, just loosen them.
to axlline, is that your car? man like that wiring. i cleand mine up a good bit, but damn that looks good. also whats with the plate on the side of the radiator? why wouldnt u want air cooling things off when u drive?
Old Sep 23, 2006 | 06:21 PM
axlline's Avatar
Default Re: (fastludeh22)
air flow gos the path of least restance, so I blocked it off to make sure all the air goes to the rad.and yes she all mine, paid off last week.
Old Sep 23, 2006 | 07:40 PM
TylerC161's Avatar
The manifold was bought, but, its for a turbo prelude.. the downpipe, is also supposed to be for a turbo prelude. The turbo, is like any other, its just a turbo. Thing is, when i flip the turbo where the intake is on the passenger side, the downpipe no longer fits and "snakes" like it should. thus why I put it this way in the first place.
Old Sep 23, 2006 | 08:08 PM
Chris F's Avatar
I can't see, is it just the intake side that's hitting? If so you can clock it.
Old Sep 23, 2006 | 08:48 PM
TylerC161's Avatar
the intake is completely sitting where the alternator is supposed to sit.
Old Sep 23, 2006 | 09:31 PM
king_me's Avatar
love-fab eq ftw
1/2 radiator is still required tho
http://www.love-fab.com
Old Sep 23, 2006 | 10:21 PM
Hawkze_2.3's Avatar
Why not just move your alternator? A custom bracket shouldn't be too hard to get made....
Old Sep 23, 2006 | 10:24 PM
TylerC161's Avatar
Default Re: (Hawkze_2.3)
where would you reccomend?
AC spot or PS spot
and what the hell would i do about the belt
Old Sep 23, 2006 | 10:28 PM
Hawkze_2.3's Avatar
I'd say AC spot if you can. Keep the alt away from the heat of he manifold...
Hasport offers an H-series alt relocation bracket in their H22-CRX mount kit that you might check out.
Old Sep 24, 2006 | 06:23 AM
axlline's Avatar
check out these brackets I am using one like the upper mount
http://explicitspeedperformance.net/H22Aalt.html
Old Sep 24, 2006 | 01:00 PM
got a pic of the dp outside the car? who did you get the mani and dp from? did you ask them how to mount it? when u flipped the turbo, did you adjust the turbine to fit with the dp?
Old Sep 24, 2006 | 02:41 PM
chihuahuamanx's Avatar
it really looks like you ned to just flip the turbo. on the few turbo preludes ive helped installs on, the dp always comes out of the left side. I might just be talking out of my ***, but that seems like a rea simple solution. On my setup I hadta trim the from engine mount a little bit (maybe 1 square inch of material) and i had to trim the shroud off of my radiator fan.either way, it should work.
And remember running into an engine bay and cutting random parts off can ONLY make your car lighter, and thus faster
Old Sep 24, 2006 | 03:22 PM
Hawkze_2.3's Avatar
Default Re: (axlline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axlline &raquo;</TD></TR><TR><TD CLASS="quote">check out these brackets I am using one like the upper mount
http://explicitspeedperformance.net/H22Aalt.html</TD></TR></TABLE>
Well, that's not going to help him at all. His compressor is in the space that the alternator goes...he can't just move it in tighter to the engine, it needs to be completely relocated (if he can't move the turbo).
Old Sep 24, 2006 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Well, that's not going to help him at all. His compressor is in the space that the alternator goes...he can't just move it in tighter to the engine, it needs to be completely relocated (if he can't move the turbo).</TD></TR></TABLE>
scrool down a little more, then you see the bracket the mounts it to the spot where a/c used to be, lol
edit: but i still think he has the turbo on backwards...
Old Sep 24, 2006 | 03:44 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
edit: but i still think he has the turbo on backwards...</TD></TR></TABLE>
Oops, I missed that I'm an idiot.
