need help...
Old Sep 23, 2006 | 03:54 PM
Jarfal's Avatar
Default need help...
hey guys im new to this forum, I have a civic SI 1.6 vtec
i got a problem in the gearbox i guess..
i was in a race when i was trying to shift into the 3rd gear but it wasnt going to 3rd with gear noise just like shifting with out a clutch, then i was trying to reverse the car the gear wasnt going to the R....
I asked some guys they said its the fork....
can any body tell me whats wrong with the gear box?
the gear box is S4 open ratio...
Old Sep 23, 2006 | 04:48 PM
Eran's Avatar
HT White Ops
1st Problem: 3rd Gear
-Most likely your synchros
2nd Problem: Reverse Gear
-At idle, put it into 1st Gear, move to 2nd, then into reverse. It stops the synchros.
Old Sep 23, 2006 | 04:51 PM
Jarfal's Avatar
Default Re: (Eran)
i tryed but the same.
Old Sep 23, 2006 | 04:54 PM
Eran's Avatar
HT White Ops
If it was your fork, then most likely, you'd be locked out of all gears. I'm guessing it's your synchros. You don't seem to know a whole lot about how a transmission works, or how to work on one. My sugguestion to you is to buy a used tranny from the classifieds, and then sell your old tranny to someone willing to rebuild it.
Old Sep 23, 2006 | 04:56 PM
Jarfal's Avatar
Default Re: (Eran)
thanx i would buy if i was in the states
Old Sep 23, 2006 | 04:59 PM
Eran's Avatar
HT White Ops
Default Re: (Jarfal)
Another good idea might be to buy a new tranny, and once you have your old one out, crack it open, and fix it. I did that in my bathroom I cracked open a 6th gen tranny and did an ISB swap, took everything apart, put it all back together like a puzzle. I learned a LOT.
Old Sep 23, 2006 | 05:03 PM
Jarfal's Avatar
Default Re: (Eran)
which one is better close ratio or open? pls give me the tranny code number so i can order...
Old Sep 23, 2006 | 05:13 PM
Eran's Avatar
HT White Ops
Order? Dude, if you order a transmission from honda, you're going to pay like $1500. Do yourself a favor, and buy an B16A or B18C transmission locally through the classifieds. You shouldn't pay more than $500.
Old Sep 23, 2006 | 05:15 PM
Jarfal's Avatar
Default Re: (Eran)
im not in the states
Old Sep 23, 2006 | 05:17 PM
Eran's Avatar
HT White Ops
Corona, California isn't in the USA?
kapelkert
Transmission & Drivetrain
Jul 2, 2012 04:23 PM
Kevykev
Acura TSX
Jul 13, 2008 09:33 AM
vietnogi
Feb 2, 2006 11:36 AM
HONDA_TEG
Apr 21, 2005 10:47 AM
brawl
May 26, 2002 11:33 AM
