Is it possible to install the full set of tail lights?
Old Sep 23, 2006 | 03:15 PM
EvenStar's Avatar
Default Is it possible to install the full set of tail lights?
I searched the FAQ and used the search engine but found nothing. Anyway, if you notice some CD5's have only a pair of tail lights on the side. Is it possible to install the tail lights on the trunk without having to weld or shave off anything?
Old Sep 23, 2006 | 04:30 PM
-RedneckDave-'s Avatar
Working
Default Re: Is it possible to install the full set of tail lights? (EvenStar)
No. The difference is explained in the accord guide I believe. It is that the 94-95 had only the outer lights and the 96-97 had lights on the trunk lid as well.
Old Sep 23, 2006 | 09:16 PM
gianinline's Avatar
Default Re: Is it possible to install the full set of tail lights? (-RedneckDave-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- &raquo;</TD></TR><TR><TD CLASS="quote">No. The difference is explained in the accord guide I believe. It is that the 94-95 had only the outer lights and the 96-97 had lights on the trunk lid as well. </TD></TR></TABLE>
That's correct, also the trunk lid is different, and the 1/4 panels from 94-95 don't align perfectly to 96-97 1/4 panels.
That means, you could fit a 94/95 tail light on a 96/97 accord, and even get the trunk lid from a 94/95 accord, but the trunk lid won't align perfectly (on the edges) to the 1/4 panels, in case you thought about doing that.... ....
Old Sep 24, 2006 | 05:25 AM
EvenStar's Avatar
Default Re: Is it possible to install the full set of tail lights? (gianinline)
Yeah... I was also thinking of taking the trunk lid from a 96-97 accord then put it in the 95-96... darn. Any other ideas?
Old Sep 24, 2006 | 06:40 AM
gianinline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">Yeah... I was also thinking of taking the trunk lid from a 96-97 accord then put it in the 95-96... darn. Any other ideas?</TD></TR></TABLE>
Body work, or.... cutting the edges of a 1/4 panel of a 94/95 and welding it to the 96/97.... which isn't worth the amount of work. If you are so crazy for the idea, just go with body work or leave it alone.....
Old Sep 24, 2006 | 09:19 AM
EvenStar's Avatar
Any idea on how long it might take and cost me?
Old Sep 25, 2006 | 06:53 PM
gianinline's Avatar
body work.... maybe 4 to 7 hours of labor (depends the mood of the estimator....) to have it done. Cutting 1/4 panels and such would be a 12 to 15 hour job, plus labor to remove and reinstall rear window.
High end shops average a 70 to 100 dollars hour labor..... at my shop will work at 35 dollars per hour.
Old Sep 25, 2006 | 07:44 PM
KillerElfboy's Avatar
Default Re: (gianinline)
translation...
12-15 hours labor X 35-70 dollars an hour= not worth it
best case scenario= 410 dollars min..
worst case scenario= 1050 dollars max
hondaman1992
Nov 30, 2011 06:08 PM
Ploeg8393
Nov 4, 2008 09:04 PM
lauren102984
Oct 7, 2007 01:59 PM
