Can 440CC injectors be too much?
Old Sep 23, 2006 | 02:57 PM
BABY NSX's Avatar
Default Can 440CC injectors be too much?
So I’ve just about ordered every part for my up and coming build but I have a quick question about the fuel injector sizing…
Here is a basic run down of what my B18C5 build consists of (from my previous post CHANGES):
Head:
- Fully port and polished by Gord Busch Performance (in Mississauga)
- Port matched intake manifold
- Skunk2 Pro1 cams
- Skunk2 Pro cam gears
- Ferrea +1mm intake valves
- Ferrea exhaust valves
- Ferrea valve springs
- Ferrea Ti retainers
- Ferrea Seat locators
- Ferrea Valve locks
- ARP head studs
Bottome end:
- Weseco Pistons (81.5mm 5cc)
- Carrillo Rods
Other:
- RC 440 injectors
- Honda Bearings
- Honda Valve seals
- Honda head gasket
Parts I already have:
- Mugen intake
- Mugen twin loop
- High-flow cat
- Spoon header
- Hondata S300
- PLX R-500
I tried to get RC 370 injectors but my supplier didn’t have them available so I opted to order the RC 440s. The guys at Skunk2 tell me I’ll have no problem tuning the Pro1 cams with these injectors (a la Honda S300) but I want to get some second opinions. My main concern is being able to get the engine to idle smoothly with these large injectors. On the positive side I know I wont max them out
My guess is that running these injectors at 50psi will likely result in a maximum duty cycle of 50-60%.
Any thoughts?
Oh, parts should be arriving over the next month or so…
Old Sep 23, 2006 | 03:07 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Can 440CC injectors be too much? (BABY NSX)
You will be absolutely fine... Yes they are a bit large for your setup however with a decent tuner you will be good. For example I just tuned a b16a on 6psi with 750cc injectors using crome pro and it is flawless
Old Sep 23, 2006 | 05:28 PM
b19coupe's Avatar
I ran 440's on a very similar build with the same cams and it idled fine-after much tuning.
Old Sep 23, 2006 | 08:36 PM
mRvYbEs's Avatar
Tuning is the key.
Old Sep 23, 2006 | 08:40 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: Can 440CC injectors be too much? (mRvYbEs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRvYbEs &raquo;</TD></TR><TR><TD CLASS="quote">Tuning is the key. </TD></TR></TABLE>
yes it is. 440 is fine especially if your going to be tunning it with hondata
Old Sep 24, 2006 | 07:02 AM
BABY NSX's Avatar
Default Re: Can 440CC injectors be too much? (2'z custom colors)
Thanks alot guys!
This definitly makes me feel alot better about choosing them. My other option was to get 310s but I figured that might be getting a little tight.
BABY NSX
Oct 26, 2006 10:22 AM
BABY NSX
17
Sep 14, 2006 08:30 PM
WONG FRIED RICE
12
Sep 6, 2006 01:01 PM
B20 EK
May 5, 2004 06:14 AM
