CRX's swaps-which model is easier to swap?
Old Sep 23, 2006 | 08:47 AM
deck1's Avatar
Default CRX's swaps-which model is easier to swap?
Hi guys! I'm planning to get a CRX but I need to know which are the easiest model to drop a B series engine as far as wiring, passing the smog, ecu, tranny, etc. Is it an HF, DX or Si? Thank you for your time!
Old Sep 23, 2006 | 08:54 AM
Tippyman's Avatar
HF and Si are already MPFI so the wiring is easier.
Old Sep 23, 2006 | 09:10 AM
E_F_9's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">HF and Si are already MPFI so the wiring is easier.</TD></TR></TABLE>
Old Sep 23, 2006 | 09:34 AM
deck1's Avatar
Thanks man! So, is your tranny is still cable or hydraulic? Was the pain in the neck to do?
Old Sep 23, 2006 | 10:10 AM
Magick211's Avatar
Default Re: (fp)
Hyrdo tranny is a easy swap if you use the hasport cable to hydro mount kit
Old Sep 23, 2006 | 10:26 AM
deck1's Avatar
Default Re: (Magick211)
Thanks for all the info!
godruler
Feb 20, 2006 02:27 PM
CoolRedXylophone
Jan 20, 2006 10:17 AM
darkstarmeyers
May 19, 2005 07:17 PM
beepbeep
May 9, 2002 12:30 PM
tanjulio
May 6, 2002 11:39 AM
