dash does not work, any advise
for the past month and a half or so, is have interm. signals, some mornings the tach wouldnt read, and the cruise would work on and off.
but the other night, i was coming home, and i heard a pop, and no dash lights, no tach, no speedo, no radio, no cruise, no odo, fuel gauge read full at all times, and no temp, and no signals.
today i checked, all my fuses, but non of them were blown, i saw the there was a wrong size fuse for the blower fuse, i put the right one in there, i started the car, now i have dash light, radio, gauges. back. but still no signals or cruise.
have any of you guys run in to such a electrical problem before
sounds to me like you have blown a fuse of some sort - I would start bt checking that -
You have have fried the board that all the signals run on too - I have seen that is several fords happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wperdigon »</TD></TR><TR><TD CLASS="quote">You have have fried the board that all the signals run on too - I have seen that is several fords happen
this isn't ford-tech.com
cruise power is from fuse 4, 7.5 amp underdash fuse panel
turn signals are powered from fuse 1, 10amp underdash fuse panel
If both the fuses are good I'd suggest that you remove the steering column shroud and do a visual check of the wire harness.
JDM H22
Nov 5, 2007 02:43 PM
