B16A Flywheel
Old Sep 23, 2006 | 05:45 AM
dbrumm's Avatar
Default B16A Flywheel
I'm doing a B16A swap into my 91 CRX si, and part of the maintenance I'm doing to the engine/tranny before I put it into the car is replacing the clutch and flywheel with an ACT street/strip (stage 1) clutch kit and flywheel. I've now gone through ordering parts twice once because I screwed up the part number and the second time because they sent the wrong part, but to make a long story short I now have a flywheel for a 2000 honda civic si and hopefully some time next week i'll have a pressure plate and friction disk for a 1991 integra ls. My question is should I use a flywheel for a 1991 integra or can I just use the flywheel I have for the 2000 civic si. Do all B series engines use the same flywheel? I can say that when I compare the ACT 2000 civic si flywheel to the OEM flywheel I just pulled off the engine they look the exact same I can lay them on top of each other and they match up I can even put the oem pressure plate onto the ACT flywheel and it fits. BUT I havent heard of anybody anywhere on honda-tech who used a civic flywheel on a B16A. Help please.
Old Sep 23, 2006 | 10:05 AM
Crx Jimmy's Avatar
Default Re: B16A Flywheel (dbrumm)
all b series flywheels are the same
Old Sep 23, 2006 | 11:05 AM
Magick211's Avatar
Default Re: B16A Flywheel (Crx Jimmy)
Really? i thought there was a differnce between the cable and hydro flywheels, learn something new everyday
Old Sep 23, 2006 | 11:22 AM
Crx Jimmy's Avatar
Default Re: B16A Flywheel (Magick211)
no, the cable and hydro ones are the same
Old Sep 24, 2006 | 08:55 AM
dbrumm's Avatar
Thanks. They looked really similar, but I just wanted somebody to verify that they were the same.
Old Sep 24, 2006 | 10:51 AM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">no, the cable and hydro ones are the same</TD></TR></TABLE>
Good info i learned something new that i should of already known
maximusej6
Transmission & Drivetrain
Nov 27, 2010 12:15 AM
fled
Jul 5, 2006 12:06 PM
remaxxxk
Mar 1, 2006 09:11 PM
del_parker
Dec 30, 2003 10:30 PM
7rrivera7
Sep 6, 2002 12:48 PM
