Front Sway Bar Questions/Suggestions
Old Sep 23, 2006 | 03:27 AM
1993 Civic Si's Avatar
Default Front Sway Bar Questions/Suggestions
I've searched for HOURS trying to find the size of the front sway bar on my 1993 Si. I've seen it posted somewhere, but can't find it now.
I'm considering upgrading the OEM bushings to ES poly bushings. I primarily autox the car in HS and this is one of the few upgrades allowed...as far as bushings.
Has anyone done this? How difficult is it? I'm guessing I should also upgrade the end link bushings. Did you notice any improvement?
TIA!!!
Old Sep 23, 2006 | 04:50 AM
UberMunkey's Avatar
Default Re: Front Sway Bar Questions/Suggestions (1993 Civic Si)
OEM front bar is 21mm
Old Sep 23, 2006 | 11:52 PM
Default Re: Front Sway Bar Questions/Suggestions (UberMunkey)
OK, thanks! So the Si and the EX have the same size. I was thinking I read the Si got a 22mm...
Any tips or installation tricks? Improvement?
TIA again!
Old Sep 23, 2006 | 11:59 PM
sol2hatch's Avatar
tip: if you work at it enough, you can avoid taking any exhaust components off by unbolting your cat and squeezing it between the pipes. Thats how i did my GSR front sway.
Good luck to you, hope you have a rear sway bar, and if you dont, you should get one. Just having a front bar will cause even more understeer in your understeer happy honda. It does give it a more solid feel though. I am about to install my Type R rear sway in my hatch to balance my car out. I cant wait
Old Sep 24, 2006 | 03:21 PM
Default Re: Front Sway Bar Questions/Suggestions (sol2hatch)
I think I read it was a 21mm last night...Helms gives NO HELP on replacing the bushings
No, mine doesnt have a rear bar. I autox the car in stock class, so I can't add one, either.
Thanks for the help!!!
Old Sep 24, 2006 | 05:15 PM
cueballsi's Avatar
if u want a bigger bar upgrade... get a integra.... it is 24 or 26 mm
Old Sep 24, 2006 | 06:52 PM
Targa250R's Avatar
be professional
Just get a complete G3 Integra front sway (or better). In SCCA Solo Stock class, you are allowed to replace the front sway bar along with its bushings, brackets, and endlinks. For a stock class car, just replacing the bushings with polyurethane isn't enough - you want a beefier front bar that is as stiff as possible to increase roll stiffness and help with camber control up front. Do you already have R-compound tires, good dampers, lightweight cat-back exhaust, and aggressive brake pads? How about your alignment? Tire pressures?
mrboompow
Feb 24, 2014 06:25 AM
TeeB16
Honda Civic (2006 - 2015)
May 18, 2008 11:56 PM
amej8
Apr 18, 2007 02:25 PM
Rouin
Mar 11, 2007 12:51 PM
jdm_23_eg6
Suspension & Brakes
Apr 3, 2005 03:32 PM
