97 ACCORD F20B SWAP INFO. PLEASE HELP !
Old Sep 22, 2006 | 06:47 PM
93DALSVTEC's Avatar
Default 97 ACCORD F20B SWAP INFO. PLEASE HELP !
I just purchased a f20b dohc auto swap for my 97 accord wagon. Can any body
help me with swap info. A few things I already noticed are the difference in the
transmission solenoids. f20b has a few more solenoids then the f22b1 (in the car). Of course the harness on the motor swap has been cut. Also no crank sensor down near the crank. I have tried to search for swap info but all I keep reading is about the h22 and f20 series differences. Any help will be great. Sorry if this has been beat around, but I really have tried to find this info on several sites without
any luck.
Old Sep 22, 2006 | 07:02 PM
momstaxi's Avatar
Default Re: 97 ACCORD F20B SWAP INFO. PLEASE HELP ! (k20AN95CPE)
i cant help you with the transmission, but for the crank sensor you should be able to use any sensor from any 97+ prelude
Old Sep 23, 2006 | 02:15 AM
93DALSVTEC's Avatar
Default Re: 97 ACCORD F20B SWAP INFO. PLEASE HELP ! (momstaxi)
SORRY, I mean I do not see a crank sensor harness running a long the timing cover to the crank pulley area. I guess it's in the distributor. I have not yet removed the timing cover though. THANKS. keep the info coming.
Modified by k20AN95CPE at 12:08 PM 9/23/2006
Old Sep 23, 2006 | 08:39 AM
93DALSVTEC's Avatar
is this swap really that different then a h22 swap ? man I was looking for a plug
and play set up. maybe a little wiring. thanks for looking. really any info would be great.
Old Sep 23, 2006 | 01:46 PM
GChambers's Avatar
You didn't bother to look at the stickies at the top of the page before asking this question?
Everything you need to know is right there.
Old Sep 23, 2006 | 04:04 PM
93DALSVTEC's Avatar
Default Re: 97 ACCORD F20B SWAP INFO. PLEASE HELP ! (GChambers)
can you give me a little more help. I did not post to start anything. Just really looking for a helping hand. If you read above I did try several times to search this
site and several others for help with out any luck. If I have to purchase or make a harness thats all I'm looking for.
Old Sep 24, 2006 | 05:58 AM
mikey012's Avatar
did you check the accord wagon club?a guy just did an obdII h22 swap in his 96,should be about the same
Old Sep 24, 2006 | 06:21 AM
93DALSVTEC's Avatar
Default Re: 97 ACCORD F20B SWAP INFO. PLEASE HELP ! (mikey012)
THANKS. I will try that.
Tight R
Jan 31, 2023 02:42 PM
Boostdprotegelx
May 30, 2016 10:29 AM
slowredsol
Sep 9, 2014 07:40 AM
jlunn717
May 4, 2012 10:42 AM
