car won't start for long time after running out of gas
Old Sep 22, 2006 | 06:26 PM
dan89crxsi's Avatar
Default car won't start for long time after running out of gas
I have a 99 Civic EX Coupe stock everything. I ran out of gas about a week ago and after going to get gas and putting some in the car it wouldnt start. I waited an hour then went back to start it again no luck. So I let the car sit for about a day or so then I go to start it and it starts right up. A week later I ran out of gas again and now the car wont start again even after putting more gas in. It has been almost a full day and the car still wont start. I thought it might be the ignition coil and the running out of gas thing was just a coincidence so i replaced the coil. Still wont start I dont get it could it be the fuel pressure regulator or what Im stumped. Please help just got my license back trying to get the POS to the inspection station. It has to be something with the fuel cause this has happened only when I run out of gas.
Old Sep 22, 2006 | 06:38 PM
wheelmanbg's Avatar
Default Re: car won't start for long time after running out of gas (dan89crxsi)
well, you should have learned not to run out of gas!
Everytime you let your car run "on fumes" it works towards ruining your fuel pump because there is nothing to keep it cool
So check to see if your fuel pump is still working...
YodajdmEK4's Avatar
STOP RUNNING OUT OF GAS ITS NOT GOOD FOR THE CAR!!!!!
Old Sep 23, 2006 | 08:22 AM
dan89crxsi's Avatar
Default Re: car won't start for long time after running out of gas (YodajdmEK4)
i know im not trying to but the car has no tags ive been trying to get it to the inspection station so i can get tags and fill her up but the **** is breaking down how do i check the fuel pump turn the power on and listen for it to turn on?
Old Sep 23, 2006 | 08:31 AM
turbociviccoupe's Avatar
is fuel even coming?
if the car runs out of gas you have to crank longer becuase there is no fuel in the lines.
turn the key to the on position and see if the fuel pump turns on
Old Sep 23, 2006 | 09:36 AM
dan89crxsi's Avatar
Default Re: car won't start for long time after running out of gas (turbociviccoupe)
i hear the fuel pump turn on when i turn the key to the on position
Old Sep 23, 2006 | 10:05 AM
how bout spark?
Old Sep 23, 2006 | 10:10 AM
dan89crxsi's Avatar
im pretty sure its getting spark i have to check i just replaced the coil maybe it is the ignitor
Old Sep 23, 2006 | 10:15 AM
NathanielH's Avatar
hold the plug wire to ground and see if it archs. better check for spark before you go replacing stuff it may not need
Old Sep 23, 2006 | 11:38 AM
dan89crxsi's Avatar
Default Re: car won't start for long time after running out of gas (NathanielH)
yeah im at work and the car is here in the parking lot i am going to go out and check for spark shortly
Old Sep 23, 2006 | 05:29 PM
dan89crxsi's Avatar
GOT SPARK!!!! i got spark and im pretty sure I hear the fuel pump cut on....whats should i check next??
Old Sep 23, 2006 | 05:39 PM
uLikeMyPreludeSi's Avatar
try changing fuel filter
craiger369's Avatar
my fuel pump was pumping but not at high enough pressure to open the injectors, replaced the pump and it started right up. Take the line off at the fuel filter, if the pump is working it should spray out when you try to start it. If it just pours/trickles then its working but not building enough pressure, which means you need to replace the pump. You may want to get a friend to help you with checking.
Old Sep 23, 2006 | 05:54 PM
dan89crxsi's Avatar
Default Re: (craiger369)
thanks man thats the next thing ill check ill let you all know what the results are
Old Sep 23, 2006 | 06:00 PM
KtHaNxBai's Avatar
Default Re: (dan89crxsi)
check ur flux capacitor
Old Sep 24, 2006 | 09:59 AM
dan89crxsi's Avatar
Default Re: (galaxykid70)
the flux capacitor is working i can go back through time i just cant start the engine for road driving (checking fuel today)
Old Sep 24, 2006 | 01:22 PM
dan89crxsi's Avatar
shes running again.......removed fuel line from fuel filter it was getting fuel put the line back on and started it up weird but hey its running and ill never let it run out of gas again! Thanks all
vartok
Jul 22, 2011 07:18 PM
01_ITR
Apr 5, 2009 07:55 PM
m3dia_lab
Nov 2, 2004 09:22 PM
Sergei01
Apr 12, 2004 11:30 PM
garagespecial
Jun 25, 2002 10:00 AM
