Cheap Honda stuff, "Random things" Check it out.
Old Sep 22, 2006 | 06:03 PM
Contender25
Guest
Posts: n/a
Default Cheap Honda stuff, "Random things" Check it out.
B series Red Nology Hotwires, used but in great condition, they got these little silver ground straps built into them. ~80$
Wings west CRX wing, primered gray, already has the spot for a windshield wiper, no cracks in great condition. ~60$
92-95 civic intake manifold, manifold only. ~20$
92-98 D series hydro transmission, 5 spd, dx/cx, works great. ~60$
Complete cast iron ZC header with bigger ports and new o2 sensor on it. ~30$
Old school chikara header, lightweight, needs a gasket and o2 sensor. ~30$
96 Y8 VTEC head, superb condition for a 96, turns over great, has a fine vtec solenoid on it, has the special "VTEC" polished valve cover on it already. ~80$
Two 5 lug TYPE R championship white wheels, dusty but clean, with two fat tires on them already in ok condition. ~80$
JSPEC DX head, basically a d15 non vtec head that IS from japan, off the base model, works is in good condition. ~50$
300 Watt Sony Xplode AMP, new like condition, works fine. ~40$
Brand new stock CRX tail lights, shiny and clean and stock red color with the CRX logo in the middle. ~50$
Brand new aftermarket CRX tail lights, all ghost clear, completely clear, all three pieces, new like glass, shiny like a mirror. ~80$
Tenzo R muffler, 5 inch i believe, needs to be cleaned, has the end cut off but can be re welded, it's in used condition, very obnoxious loud, straight through. ~20$
92-95 OBD1 Distributor, came off a dx, one side is broken but two bolts can still be used to hold it on perfectly fine, has everything inside it, coil pack and igniter and cap and rotor. ~40$
88/89 CRX SI swirly rims, sprayed a shitty black color, has all 4 tires on them. ~80$
Thats it, leave a reply or instant message me, my AIM is also RoyalHatchback if you wanna drop me a message.
ej8_fredi
Sep 16, 2008 04:33 PM
sohcboost06
Jul 19, 2007 02:56 PM
Contender25
Sep 24, 2006 12:35 PM
Sketch_hs
Northern California (Sales)
Jul 30, 2006 05:27 PM
