Advance Design suspension
Used set of Advance Design shocks for an Integra Type-R (or 3rd gen integra, EG/EK civic with Type-R rear lower control arms). Shocks were rebuilt July '04, have seen 3 track days and have been sitting on the shelf since Sept '04. Shock dyno's can be obtained from Advance Design.
Advance Design shocks are single tube, aluminum (very very light - the springs actually weigh more than the shocks), and dual independently adjustible for compression and rebound. Compression adjustment has 3 distinct settings. Rebound has 3 complete turns of the adjustment **** with an infinite number of positions. Both compression and rebound are adjustible while the shocks are installed via ***** on the top at the shock towers.
The top hats are OEM ITR.
Although these shocks are designed for track use they can be used for limited street duty. I've put about 1500 street miles on the getting to/from the track.
Advance Design (http://www.advance-design.com) is the racing shock branch of Ground Control (http://www.ground-control.com) and these shocks are serviceable, if ever needed, at their offices in CA.
$1000 shipped or best offer
References available if necessary
Honda Gen
54
Jul 26, 2011 09:56 AM
