88 crx dx no heat?
Old Sep 22, 2006 | 03:17 PM
88crxhfb16's Avatar
Default 88 crx dx no heat?
Heater is blowing cold air? coolant is good. no losing any at all. any ideas what to check?
thanks
Old Sep 22, 2006 | 03:34 PM
philkehn's Avatar
im running a b16 as well and i am having the same problem so if any one can help
'90crxSI's Avatar
Default Re: 88 crx dx no heat? (88crxhfb16)
Thermostat?
Old Sep 22, 2006 | 04:06 PM
CRXDaddy78155's Avatar
hmm...There aren't too many things that it could be aside from your thermostat the only things I can think of are:
Broken Heater Valve (Under the hood)
Bad Heater Core (may be able to flush it)
Air Mix Cable (you may want to follow this cable to see if it is still connected the way it's supposed to be; that's what was wrong with mine)
Heater Valve Cable (inspect and follow)
If all of these are ok then I haven't the slightest clue.
oh....you may want to make sure that your A/C button is NOT on.
Old Sep 22, 2006 | 05:09 PM
88crxhfb16's Avatar
Default Re: 88 crx dx no heat? (88DXREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXREX &raquo;</TD></TR><TR><TD CLASS="quote">hmm...There aren't too many things that it could be aside from your thermostat the only things I can think of are:
oh....you may want to make sure that your A/C button is NOT on.</TD></TR></TABLE>
AC belt is not hooked up, so it wouldnt mattter lol. thanks
gonna check the air mix cable tommorow. doesnt feel like the dial (hot/cold) has any tension on it, so it could be that. thanks for the advice
Old Sep 24, 2006 | 09:52 AM
Bump for Update!
724chris
Nov 19, 2009 12:11 AM
ppl talk bout my old name
Dec 21, 2005 02:15 PM
TheIceMan
Feb 20, 2005 02:20 PM
4DRmafia
Jul 11, 2004 02:07 PM
speedbeast
May 9, 2004 01:53 PM
