Wut spark plugs to run??
Old Sep 22, 2006 | 02:07 PM
Eg_TypeR's Avatar
Default Wut spark plugs to run??
Hey guys....
I wanted to change my plugs, I have been using the stock Type R platinum plugs for the past 2 seasons since i finished the build, but I spoke to someone 2day and told me i shouldnt run platinum plus, he recomended a basic plug that could be gapped to my specific need..... He mentioned something about the high compression wouldnt be good with platinum plugs???
Wut do u guys think?? Thanx!!
Here is the setup:
B18c5
stock rods and crank
CTR pistons
CTR crank pulley
Mild porting job
Jdm integra R cams
bored out tb and intake man.
hondata intake man. gasket
all the little bolt ons.... AEM fuel rail, press. reg., CAI, and more
Full MSD setup
DC JDM 2.5" header
2.5" custom midpipe with Spoon exhaust
Old Sep 22, 2006 | 02:17 PM
DonF's Avatar
Default Re: Wut spark plugs to run?? (Eg_TypeR)
After running your car for 2 seasons, with good results, why would you listen to a dork? If you have had problems, then ask the question, after 2 seasons it sounds like you are doing OK. I personally do not use "platinums" but I also do not run plugs 2 years either.
Old Sep 22, 2006 | 04:52 PM
Eg_TypeR's Avatar
Default Re: Wut spark plugs to run?? (DonF)
they werent run for 2 years....
last season they were used for about a month, and this year for prolly another 4 months... I dont drive my car in the winter, and it is only taken out for a drive 2-3 days a week....
and u said u dont use platinum... is it a b-series??
Old Sep 27, 2006 | 06:47 PM
Eg_TypeR's Avatar
Anyone Else??....
id like to hear wut u guys r running in ur cars??
Old Sep 27, 2006 | 06:53 PM
SkoundrelUSA's Avatar
cute little bastard
I'd use NGK V-power BKR7E-11s gapped to .035
Old Oct 5, 2006 | 02:52 PM
blinx9900's Avatar
platinum and high compression should be fine, stock NSX spark plugs are double platinum and there CR is 11:1... good luck in your quest...
Old Oct 5, 2006 | 04:14 PM
DonF's Avatar
Default Re: Wut spark plugs to run?? (cusco9900)
What is "double" platinum? Twice the number in the chemical table? That would make "unubtainium" Or just double the price?
Old Oct 9, 2006 | 10:45 AM
blinx9900's Avatar
double platinum means that the spark plug electrode is platinum and there is a piece of platinum welded to the ground (fish hook looking thing) so there is platinum between both sides of the spark... check out sparkplugs.com for more info and pictures if this dosent make sense.
Old Oct 9, 2006 | 04:15 PM
d16dcoe45's Avatar
Try a Champion C61cx or c63cx (equal to an NGK 8 and 7 respectivley) Yeah platinum is for the birds.
Old Oct 9, 2006 | 04:22 PM
91SiZ6's Avatar
Stock NGK. They're cheap enough that if they don't work you can go back to the bling plugs.
Old Oct 15, 2006 | 06:33 PM
HybridEarthquake's Avatar
Default Re: (91SiZ6)
I was using plat's for 2 years(not the same plugs the whole time) before switching to standard NGK's this last spring. I felt a difference (using my ***-dyno) the first time down the street. Not a good difference either. I will finish out these NGK's, then switch back to plat's in the spring.
Old Oct 16, 2006 | 01:30 AM
boostng r's Avatar
a
i use bcpr7es ngk
just went to a 8 v power ngk
Old Oct 16, 2006 | 01:58 AM
92TypeR's Avatar
FSAE
Default Re: (HybridEarthquake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridEarthquake &raquo;</TD></TR><TR><TD CLASS="quote">I felt a difference (using my ***-dyno) the first time down the street. Not a good difference either. I will finish out these NGK's, then switch back to plat's in the spring.</TD></TR></TABLE>
I belive Copper has higher conductivity when compared to Platinum, which means less resistance and more power. Only problem with Copper is that it is not as durable as platinum, and needs to be replaced frequently. I think the cost makes up for this fact, as you can get a set of V-power's for around $10, where the platinums are $45/set. I replace mine every other oil change.
Old Oct 16, 2006 | 04:30 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: Wut spark plugs to run?? (SkoundrelUSA)
I run NGK BRK6E-11s, but a friend with a H/C LS/VTEC run 7E-11s. That's a good, cheap plug.
sa90eg
Oct 24, 2005 06:08 PM
Used2beAb16
Mar 2, 2005 09:19 PM
P1mpSlap
Sep 25, 2003 09:41 PM
combustion
Sep 18, 2002 05:56 PM
808eg6
Jan 25, 2002 07:03 AM
