d series piston rings for my a6 pistons..correct?
Old Sep 22, 2006 | 01:37 PM
mattie_96's Avatar
Default d series piston rings for my a6 pistons..correct?
The hastings piston rings finally came in for my z6(even though im using a6 pistons..they should be the same as far as part number states)
ANyways after looking at the helms manual it states that the TOP rings for the z6 and d15z1 should look below
the part number is 2C 4640, HONDA-ACURA B27A 'CHROME' 4CYL barcode 0 75538 16314 5
Old Sep 22, 2006 | 09:27 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
you should order rings for the piston they are intended to go on, not the bore they are intended to go in.
the helms has clearance specs for the width of the ring grooves. i would go through all of those and pay attention for any tightness, meaning a ring was too thick for its intended groove.
Boyle.R
Jun 21, 2014 12:38 AM
averyvm
Apr 5, 2007 07:25 PM
Doggett3
Feb 1, 2006 01:46 PM
