Creaking sound from front driver wheel
Old Sep 22, 2006 | 11:30 AM
timaa66's Avatar
Default Creaking sound from front driver wheel
I have a creaking/clicking sound in my drivers side front wheel during acceleration in forward or reverse almost all gears seems to occur when torque is put on the wheels anyone know what this is? Btw it does not make any noise during turns hard or soft only when torque is applied during acceleration.
thx,
tim
Old Sep 22, 2006 | 12:09 PM
timaa66's Avatar
bump plz help
Old Sep 22, 2006 | 12:17 PM
noz79's Avatar
Default Re: (timaa66)
What year is your car? Mileage, swap done to it? Recent work done on it, when did it start happening?
Old Sep 22, 2006 | 12:25 PM
pat92si's Avatar
Default Re: (noz79)
could be the axle going bad or installed incorrectly
Old Sep 22, 2006 | 12:27 PM
jtchinoy's Avatar
did you do anything to your suspension (particularly the upper control arm)?? Like put in a camber kit or the such? If it's a thud kind of noise, check all of your bolts, including the ones for the control arm/ camber kit. I had a thud/ click noise for a while like that, turns out I didn't tighten my bolts all the way on the camber kit. Make sure they're nice and tight.
Old Sep 22, 2006 | 12:37 PM
philosofy1's Avatar
Default Re: (jtchinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy &raquo;</TD></TR><TR><TD CLASS="quote">did you do anything to your suspension (particularly the upper control arm)?? Like put in a camber kit or the such? If it's a thud kind of noise, check all of your bolts, including the ones for the control arm/ camber kit. I had a thud/ click noise for a while like that, turns out I didn't tighten my bolts all the way on the camber kit. Make sure they're nice and tight.</TD></TR></TABLE>
yes, doesn't hurt to double check everything. i would have to say it is your axle. not all the time when an axle goes bad does it mean that it will click when you turn.
Old Sep 22, 2006 | 01:12 PM
timaa66's Avatar
i recently did a motor swap its a 99 civic ex and i put the stock motor back into it 95,xxx on car 76,xxx on motor started soon after the swap i was thinking it was maybe that i didnt clean the ball joint and possibly there is some dirt in it causing it not to seat properly is this possible?
Stiff_Crx
Oct 8, 2009 05:14 PM
polyamorousDA
Aug 19, 2007 06:47 PM
vgsr
May 29, 2005 09:26 PM
Integra_RS
Apr 21, 2005 07:45 PM
thickfacek
Feb 9, 2003 09:08 AM
