would a crx hf run with an si ecu?
Old Sep 22, 2006 | 07:40 AM
rice a roni's Avatar
Default would a crx hf run with an si ecu?
or would it not?
Old Sep 22, 2006 | 07:51 AM
crxnj's Avatar
Default Re: would a crx hf run with an si ecu? (rice a roni)
yes,but when you put it in reverse it will sputter or even stall
Old Sep 22, 2006 | 07:54 AM
Default Re: would a crx hf run with an si ecu? (Mr.speaker)
hmm...i put a socketed ecu with an si basemap and it doesnt even start..then i threw in my hf ecu and it started.
Old Sep 22, 2006 | 07:57 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni &raquo;</TD></TR><TR><TD CLASS="quote">hmm...i put a socketed ecu with an si basemap and it doesnt even start..then i threw in my hf ecu and it started. </TD></TR></TABLE>
maybe its a bad burn..the stock si ecu will defineatly run a stock hf..not perfect but it will start and go
Old Sep 25, 2006 | 01:26 PM
haha im stupid...i didnt know that putting the chip in backwards would make a no start.
Old Sep 25, 2006 | 01:40 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni &raquo;</TD></TR><TR><TD CLASS="quote">haha im stupid...i didnt know that putting the chip in backwards would make a no start.</TD></TR></TABLE>
um yeah.
Old Sep 26, 2006 | 09:05 AM
Default Re: would a crx hf run with an si ecu? (Boosted Chemist)
so umm...it runs kinda of rough..normal?
Old Sep 26, 2006 | 09:09 AM
CRX Toad's Avatar
Why not just get HF ECU? If you take that motor to high RPM's your 8 valves are going to cough.
Old Sep 26, 2006 | 10:27 AM
driveahonda's Avatar
I know for a fact you cannot run a Si with a HF ecu. But I dont know if its the same the other way around.
Old Sep 26, 2006 | 05:17 PM
marquisdee1018's Avatar
Just curious, why would you run a HF with a Si ecu?
Old Sep 26, 2006 | 05:23 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">yes,but when you put it in reverse it will sputter or even stall</TD></TR></TABLE>
What does reverse have to do with it?
Old Sep 26, 2006 | 07:06 PM
Serdar's Avatar
Default Re: would a crx hf run with an si ecu? (Tippyman)
Yea I put a pm6 ecu in my 91 hf it didnt stall nor sputter. if left it in for a long time, you would probably run rich and possibly foul your plugs.
Old Sep 26, 2006 | 07:35 PM
thehatchninja's Avatar
there will be no performance advantage those two motor are too different
Old Sep 26, 2006 | 07:53 PM
domo_kun's Avatar
Old Oct 3, 2006 | 05:47 AM
Default Re: would a crx hf run with an si ecu? (domo_kun)
hey guys...i wasnt trying to run my crx hf with the si ecu...i bought an pm6 ecu and i decided to try if it would work. so bottom line is i was trying to see if the pm6 functioned...i already have an hf ecu. its the sohc zc thats going in after i finish rebuilding it.
Old Oct 3, 2006 | 01:07 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">What does reverse have to do with it?</TD></TR></TABLE>
Because the hf has the reverse lights wire going to the ecu,,i dont know why honda did it,,but just go find the pinout for 88-91 hf and you'll see....alot of people have problems with the car stalling or acting strange in reverse so you just cut or pull the wire at pin b9 if your having problems
Old Oct 8, 2006 | 09:49 PM
RA122324's Avatar
Hmm, I've heard of swapping Si ecus but not between the Si and HF. Either way, let us know how it works out.
P.S. Let me know if you need an ECU.
98bucket
Jul 22, 2010 09:32 AM
CRX MASE
May 19, 2008 03:27 PM
baked_beanz
Apr 4, 2005 09:41 AM
1990-hf
15
Feb 19, 2005 08:38 PM
twin rex's
Feb 27, 2004 03:57 PM
