Startup Problem - B18A in EF
Old Sep 21, 2006 | 11:06 PM
ivan1985's Avatar
Default Startup Problem - B18A in EF
I just completed my B18A swap in my 91 Si and when I start it up it jumps to 3000 rpm and stays there. I think i'm forgetting a hose or something...
Any suggestions?
Old Sep 21, 2006 | 11:10 PM
keepitngga1's Avatar
Default Re: Startup Problem - B18A in EF (ivan1985)
maybe ur starter is bad..and the 3k reving, double check vaccum lines and also look up a thread on how to check if your tps(throttle position sensor) is workin properly
Old Sep 21, 2006 | 11:13 PM
ivan1985's Avatar
Default Re: Startup Problem - B18A in EF (keepitngga1)
It starts up awesome, it's just that it jump to 3000rpm right away!
Old Sep 21, 2006 | 11:20 PM
yea definately check the vacuum lines or it might be the tps...i had the similar problem on my b16 and it was my tps that was shot
Old Sep 21, 2006 | 11:59 PM
ivan1985's Avatar
Under my throttle body I see two nipples with no hoses on them...they look like they should be coolant hoses...
Old Sep 22, 2006 | 12:03 AM
are u able to take a pic of it?
Old Sep 22, 2006 | 12:15 AM
ivan1985's Avatar
Yah just a sec...
Old Sep 22, 2006 | 12:27 AM
ivan1985's Avatar
I took a lot of pics. Is everything hooked up correctly?
Under TB:
Old Sep 22, 2006 | 12:51 AM
ivan1985's Avatar
ttt
Old Sep 22, 2006 | 02:02 AM
hmmm good question i tihnk that might have to be hooked up to something regarding the coolant, ill take a look at my setup later on today and repost the answer
Old Sep 22, 2006 | 02:30 AM
RexQ's Avatar
are you using the stock map sensor? i think you might need the b18a one, cause on that one there are two units instead of just one like yours. one goes to something with fuel, i think fpr and the other unit goes for vacuum which in my opinion doesnt look right at all. i say vacuum issue going on there
Old Sep 22, 2006 | 03:15 AM
ace42004's Avatar
Default Re: Startup Problem - B18A in EF (RexQ)
bump cause i have a LS in a 89 hatch with the same problem
Old Sep 22, 2006 | 05:12 AM
unusual71's Avatar
maybe just my imagination (or im blind) but should something be connected to there maybe?
Old Sep 22, 2006 | 06:26 AM
Loserkidwac's Avatar
Default Re: (unusual71)
Yea that does look like a open vac ports...check the TPS it should be reading .45v at idle between the red and green wire, also try adjusting the throttle cable, my swap did that becuase I broke the TPS plug off once I fixed it would idle low...There is a vac diafram on the TB on ODB0 cars I believe to control the hot/cold idles where OBD1+ the ECU has more control over it...Don't quote me on that thats what I concluded from some stuff I have seen, in order to get the my car to idle right I set the trhottle cable so start up idles was around 1500 rpms once it runs for a min or so it drop down to normal around 800 or so rpms
Old Sep 22, 2006 | 09:39 AM
ivan1985's Avatar
Default Re: (Loserkidwac)
Do I need to use the B18 map sensor for sure?? Can somebody confirm this?
Old Sep 22, 2006 | 09:53 AM
civickiller's Avatar
Default Re: (ivan1985)
no you dont need a b18 map sensor. buy some carb cleaner and spray everything down on your IM and see at which spot does your idle hick up. because carb cleaner will stall your motor so where ever your spraying, if it starts to hick up on the idle then you know its sucking in that carb cleaner and theres your leak
Old Sep 22, 2006 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan1985 &raquo;</TD></TR><TR><TD CLASS="quote">Do I need to use the B18 map sensor for sure?? Can somebody confirm this?</TD></TR></TABLE>
Thats BS you can use either, just make sure you are using one...OBD0 has it mounted on the firewall where OBD1+ has themmounted on the TB
Old Sep 22, 2006 | 09:59 AM
ivan1985's Avatar
Can somebody look at my pics and tell me if everything looks hooked up correctly?
Old Sep 22, 2006 | 10:39 AM
Well is that port on the back of the intake mani plugged? the one someone circled...it also looks like your mp sensor on the fire wall is plugged in but there isn't a vac line going to it?
Old Sep 22, 2006 | 12:30 PM
ivan1985's Avatar
There is one vac line going to the MAP sensor, and yes the port on the back of the manifold is plugged...
Old Sep 22, 2006 | 12:45 PM
shortyz21's Avatar
holy expletive. your ***** all fubared.
hook up your map.
hook up your FITV and IACV (FITV might be removed who knows)
also to hook up coolant lines to those spots is a royal **** when the motor is in the car.
good luck.
Old Sep 22, 2006 | 02:15 PM
ivan1985's Avatar
Default Re: (shortyz21)
Isn't my map hooked up? I was told I do not need those coolant ports hooked up as I live in Vancouver and Tb does not need coolant running through it.
What about my IACV?
Old Sep 22, 2006 | 02:47 PM
ivan1985's Avatar
Ok so it was the throttle cable so nevermind about the jumping to 3000rpm now.
These are the issues now:
-Starts up good
-Idles like ****
-Dies after 1 min
-Hold the gas at a constant rpm and it sounds like crap and stutters
-Sounds good when I rev it up and down
Old Sep 23, 2006 | 02:06 AM
ivan1985's Avatar
-Starts up good
-Idles like ****
-Dies after 1 min
Old Sep 23, 2006 | 11:04 AM
b16civster's Avatar
ok do you see the pod that the tb is connected to??????? un plug that and run that hose to your map sensor and the hose that your map sensor is connected to now is suposed to go to the charcole canaster at the pass side of the bay... also if you dont hook up those coolant hoses to the bottom of the tb it WILL idle differently (cold or hot not sure witch) because there is a temperature sensitive mechanical switch that open or closes (not sure i furgot) when the engine gets warm. hope this helps
