WORLDS FASTEST 4WD!
Old Sep 21, 2006 | 09:30 PM
Drew Peacock's Avatar
Default WORLDS QUICKEST 4WD!
http://www.youtube.com/watch?v=pHR9P6S_F0o
Kiwis have done it again.
Sorry if repost just got interweb back.
Old Sep 21, 2006 | 09:34 PM
DaveF's Avatar
Default Re: WORLDS QUICKEST 4WD! (turbozxi)
jeeeze, and he even took the long way down the track......
Old Sep 21, 2006 | 09:55 PM
FMUNK's Avatar
Is that 1320ft? That looked like a fun ride!!
I guess we should all chip in and send John Shephard down for a MATCHRACE!!!
Old Sep 21, 2006 | 10:33 PM
steve1320's Avatar
Old Sep 21, 2006 | 10:58 PM
Default Re: WORLDS QUICKEST 4WD! (FMUNK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMUNK &raquo;</TD></TR><TR><TD CLASS="quote">Is that 1320ft? That looked like a fun ride!!
I guess we should all chip in and send John Shephard down for a MATCHRACE!!!</TD></TR></TABLE> YEAH 1320.
Old Sep 22, 2006 | 04:25 AM
NOPIDRAGS's Avatar
That did not look like an AWD car. It looks like a rwd Skyline.
Old Sep 22, 2006 | 04:50 AM
BoogieDownBrown's Avatar
Default Re: WORLDS QUICKEST 4WD! (NDRATECH)
Some of the skyline were AWD. they have a button that can switch the car from RWD to AWD kinda like having 4 wheel drive on a truck.
I remember years ago at E-town. the guys from Japan bought one over for the race and it had the same features. so thats what i'm guess this skiyline has as well.
it must be nice to have the option to heta up the back tires and then have the luxury to have the AWD at the flip of the switch.
And even if this is not AWD....it is definitly the fastest somethig. 7.59 on a small tire car is definilty hauling ***.
Old Sep 22, 2006 | 05:11 AM
MrMacros's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NDRATECH &raquo;</TD></TR><TR><TD CLASS="quote">That did not look like an AWD car. It looks like a rwd Skyline.</TD></TR></TABLE>
its awd with rwd for the burnout
Old Sep 22, 2006 | 06:36 AM
NOPIDRAGS's Avatar
Default Re: WORLDS QUICKEST 4WD! (BoogieDownBrown)
It is fast, no doubt about that.
It's cool either way, to see it run those times.
Old Sep 22, 2006 | 07:29 AM
hondaguyef's Avatar
190MPH!!!!!
Old Sep 22, 2006 | 08:28 AM
MidShipCivic's Avatar
Some of you know nothing about the skyline it uses a hydraulically controlled center differential and its really 4wd not awd.
The the Transmission ECU is tunable and it can be a selectable RWD only before they used a master cylinder and pressurized the clutch packs disabled the hyrdo pump and did a rwd burnout
Now you can buy an ECU and replace the OEM transnmission ECU.
I dont think J. shepeard can match that in a Talon since he cannot warm up his rear tires.
Here's a schematic from my Service manual.
Old Sep 22, 2006 | 08:35 AM
tony1's Avatar
Default Re: (MidShipCivic)
Maybe a dumb question, but what's the difference in AWD and 4WD?
Old Sep 22, 2006 | 08:38 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (tony1)
AWD I think is on at all times. 4WD with a switch?
Old Sep 22, 2006 | 08:55 AM
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe a dumb question, but what's the difference in AWD and 4WD?</TD></TR></TABLE>
Awd is a car that drives 4 wheels ALL THE TIME , full time 4wd you can also call it.
4wd ( some ppl also call these cars w/ no center differential w/ selectable t-case) Well its a drivetrain that cant or doesnt drive 4 wheels all the time. The skyline actively switches between 4wd/rwd the system works so damn good the banned the GTR from touring car because the teams tuned the drivetrains ecu.
The ecu I have can do this :
In drag mode it operates as follows:
Channel 1: constant 4WD
Channel 2: constant 4WD, lower percentage front torque
Channel 3: constant 4WD until 180km/h, then gradual release to RWD
Channel 4: constant 4WD until 140km/h, then gradual release to RWD
In circuit mode it operates as follows:
Channel 1: rapid transition to 4WD under acceleration, RWD only above 160km/h
Channel 2: gradual transition to 4WD under acceleration, RWD only above 160km/h
Channel 3: gradual transition to 4WD under acceleration, RWD only above 120km/h
Channel 4: RWD only
Old Sep 22, 2006 | 09:02 AM
boosted_TSi's Avatar
would love to know how much that thing weighs...and the actual power numbers...
anyone know ???
Old Sep 22, 2006 | 09:05 AM
tony1's Avatar
Gotcha.
Old Sep 22, 2006 | 09:27 AM
boosted94cx's Avatar
* B A N N E D *
MidShipCivic...you're a ******* douchebag
but, sadly, i must thank you for the info
Old Sep 22, 2006 | 09:30 AM
93turbo16's Avatar
That is pretty badass. Thanks for that info.
Old Sep 22, 2006 | 09:31 AM
Default Re: (boosted94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">MidShipCivic...you're a ******* douchebag
but, sadly, i must thank you for the info</TD></TR></TABLE>
Old Sep 22, 2006 | 11:46 AM
AllMotorMark's Avatar
i wonder what kinda trans setup that thing has, man either a nice auto setup or that guy can shift like a bad ***....
launching in rwd mode is a huge advantage , over awd setups like talon's have
nice car
Old Sep 22, 2006 | 11:48 AM
Default Re: (AllMotorMark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMark &raquo;</TD></TR><TR><TD CLASS="quote">i wonder what kinda trans setup that thing has, man either a nice auto setup or that guy can shift like a bad ***....
nice car </TD></TR></TABLE>
No he left in 4wd .
Old Sep 22, 2006 | 12:18 PM
integranator's Avatar
When it comes to launching a Skyline, since it is 4wd and not awd-- all the power goes to the rear wheels, so you'll see a little bit of smoke before the electronics kick in, sense the spin, and then engage the 2 fronts.
Old Sep 22, 2006 | 12:31 PM
Default Re: (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">When it comes to launching a Skyline, since it is 4wd and not awd-- all the power goes to the rear wheels, so you'll see a little bit of smoke before the electronics kick in, sense the spin, and then engage the 2 fronts. </TD></TR></TABLE>
A full time 4wd car will smoke it's tires up in a launch they have LSD in there center diff to transfer there power to the front if there rears slip . The GTR's is just electronic and ideal the system isnt slow reactinge thier. It gets as much as 50% to the front wheels upon launch..
Old Sep 22, 2006 | 12:44 PM
VisualAutoMotoring's Avatar
God that guy has ***** to stay on it like that after almost crossing the center line
Old Sep 22, 2006 | 01:03 PM
* B A N N E D *
hmm...my friends R32 GTR sure did launch in RWD only............. you can come around a slow corner, stomp it...and as soon as boost goes on it'll toss the rear end out and not spin the fronts at all.
