IAT code
i have an IAT code and i dont know how to get rid of it. i think it might not even be wired right, i would ohm the wires and see if there in the right spot on the ecu but i dont know wat spot they go in on the ecu? does ne one knw were i can get a diagram of the ecu or can help with ne thing? thanks
Also for more help troubleshooting if you look in the round plug near your fuse box the 2 wires go through there. They are right next to each other in the middle if you need i can explain exactly which 2 but you should be able to find them using the colors of the wires at the connector and ecu.
civickid03
Jul 24, 2006 06:35 PM
xx89civicracer89xx
Feb 17, 2006 11:36 AM
