J&S Safeguard Help
Old Sep 21, 2006 | 05:15 PM
REDBARON's Avatar
Default J&S Safeguard Help
Can anyone tell me which wire I'm supposed to cut for the ignition wires?
I need to cut into this wire and connect the white wire to the distributor side and the green wire to the ecu side, but I can't figure out which wire it is.
If anyone knows this information, please throw me a bone.
Old Sep 22, 2006 | 06:48 PM
REDBARON's Avatar
Default Re: J&S Safeguard Help (REDBARON)
Up please. I need some help here.
Old Sep 22, 2006 | 10:43 PM
mahatma's Avatar
J&S safeguard?
Old Sep 23, 2006 | 08:17 AM
REDBARON's Avatar
Default Re: J&S Safeguard Help (mahatma)
Yes, the J&S Ultra Safeguard. I need help with the ignition wire. I believe I'm supposed to cut into the ignitor wire but I'm not sure which one that is.
Old Sep 23, 2006 | 09:39 AM
Blaze45's Avatar
Brrraaaap!
Bump for a legit question.
Old Sep 23, 2006 | 10:01 PM
mahatma's Avatar
Default Re: J&S Safeguard Help (Blaze45)
LOL....is it an alarm? turbo timer?
Old Sep 24, 2006 | 05:36 PM
Blaze45's Avatar
Brrraaaap!
Its a device that reads knock and can pull timing from an individual cyl. to keep your engine from blowing up.
Old Sep 24, 2006 | 05:39 PM
IndySporty's Avatar
the ignitor is the fat white wire the thin white wire is for the TDC sensor. If you compare the white wires beside eachother you'll see one of them is a bit larger than the other. Hope this helps?
Old Sep 24, 2006 | 07:08 PM
REDBARON's Avatar
Default Re: (IndySporty)
Is this at the 8 pin connector where the 2 wires are located?
REDBARON
Sep 22, 2006 06:51 PM
REDBARON
jisecup
Jul 9, 2003 02:53 PM
maxim
Jan 19, 2002 06:00 PM
