f and h tranny. need help
Old Sep 21, 2006 | 02:29 PM
h22PreludeSi's Avatar
Default f and h tranny. need help
ive got a perfectly good f series tranny out of a 95ish accord sitting in the garage. only thing wrong with it is the bell housing is cracked. now i have heard that the internals are interchangable with h series. now my tranny (stock jdm h22) is taking a huge dump on me. sincros are almost gone in 3 and 5 and starting to go in 2 and 4. i am pulling the engine out over the winter to build it for turbo and i was wondering what is my best bet here... hybrid h/f tranny or just get a rebuild kit from honda.
help please
-Gavin
Old Sep 21, 2006 | 03:24 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: f and h tranny. need help (h22PreludeSi)
just use the the parts you have...everything is interchangeable.
Old Sep 24, 2006 | 05:46 PM
Default Re: f and h tranny. need help (AnthonyG2003)
are the gears any different? or should i just use the yncros from the f tranny? also what about this gm syncromesh **** should i try this or just stick to honda genuin?
-Gavin
Old Sep 24, 2006 | 06:38 PM
InvaderTrax's Avatar
The gear ratios for the Accord transmission are much taller, so it'll kill your acceleration (unless you're putting on a massive turbo). If you haven't tried GM synchromesh, give it a shot. Make sure to ask for part #12377916
Old Sep 24, 2006 | 07:04 PM
CleanSRV's Avatar
Default Re: (InvaderTrax)
how reliable are the f-series trannies for turbo? are they much weaker than the h-series?
i am planning on using a m2s4 for my build but i have always toyed with the idea of an f-series, just for the gear ratios...
Old Sep 24, 2006 | 09:52 PM
AsiAnVenOm's Avatar
f/h trannies are exactly the same just different gears...in my opinion the f-tranny will last you longer with turbo due to longer gears...
Old Sep 25, 2006 | 09:52 PM
thanks alot guys this really helps. thanks esp for the part number im going to go pick some up this weekend and try it out
-Gavin
BryantReyes
Transmission & Drivetrain
Mar 27, 2015 09:45 PM
94DCTeg
Aug 8, 2011 12:20 PM
iongerz
Sep 10, 2004 07:52 AM
dustrag
Jan 27, 2004 12:11 PM
jdmCivic925
Oct 20, 2003 11:07 PM
