air conditiong problem please help 96 vtec prelude !!??
heres the story. my airconditoner was working fine until tuesday i had a local shop install a vafc controller. he did and the vafc was broken, he just left it on my car, the scroll wheel would light up but no display. so i drove my car home barely made it. it was running terrible, and when i got home i took the vafc out and plugged all my ecu wires back in( he hard wired the vafc) and now my air conditioner does not work the next day when i go to turn it on. they compressor kicks on(i can hear it) but it blows no cold air out. i checked to see if it had antifreeze and it is over full. when i was on the freeway last night it felt like it was sort of on but not really. also when i come to a stop and then accelerate it seems like it kicks on a little bit. i have no idea what else to try. i have checked all fuses, checked the pressure, and thats about it. so would messing with my ecu have anything to do with this anyone know what i should do thanks ??
Guest
Posts: n/a
My a/c didn't work after I paid for the FREON. Gayed!. My A/C compressor was out I believe. There was power but the "A/C clutch" didn't kick in.
1. You should sue or kick this guys ***. It maybe you have no power on the A/C compressor.
A) You can take a VOLT meter (borrow / buy -autozone) and Check to see if you have power. All you need to do is go down to the A/C compressor.
B)Unplug the 3 Pin? or 2 pin? i forgot...out of the A/C compressor which is attached to the Radiator..shroud.
C) Unplug it, use the volt meter check power.
2. WIRING. He may have "cut / hotwired/ fried" the A/C wire(s).
3. could be your A/C clutch.
4. You don't need A/C it's Autumn NOW.
5. I am about to remove mY whole A/C system. Weight reduction with power gain.
6. Preludes comes w/ windows and a moonroof. Good enough. Just
dLo GSR-stolen-now-WRX
Jan 21, 2003 07:34 PM
96, ac, air, cold, compressor, conditioner, conditioning, crx, honda, kicks, prelude, problem, problems, remove, vtec
