Removing/installing Front Fenders 1988 CRX
pretty self explanatory. take off the corner light first. then just remove all the 10mm bolts. just go thru the door hinge area to get at some of the bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">pretty self explanatory. take off the corner light first. then just remove all the 10mm bolts. just go thru the door hinge area to get at some of the bolts.</TD></TR></TABLE>so they are all accessible through the corner light and through the door hinge without removing anything other than the corners??
Yup. Just take all the 10mm bolts out and remove. Some are in the engine bay, some underneath the fender and a few near the door hinge as previously mentioned. Take a good luck around, you'll see them.
