Timing belt question
Old Sep 21, 2006 | 12:32 PM
'90crxSI's Avatar
Default Timing belt question
Ok guys, I have searched and did not get an answer to this question. I bought my car from the previous owner who thought it had the SI engine. He then purchased a timing belt for it, as well as water pump. I know the water pump will fit my setup, but not sure about the timing belt? I have a d15b2 instead of the d16 that the si comes with. Someone swapped my si motor out for a dx motor. Now, the question is, the timing belt I have has 107 teeth. If I'm not mistaken, the SI engine takes a belt with 107 teeth, but the d15, does it take the belt with 106 teeth? Thanks in advance!!!
Old Sep 21, 2006 | 01:05 PM
dr_latino999's Avatar
Default Re: Timing belt question ('90crxSI)
The D15B1/B2/B7 all require a timing belt of 106 teeth. Now I don't know if the waterpump gears are the same between the A6 and B2 pumps. Just reference part numbers. If you get the same number for both, they are the same.
Old Sep 21, 2006 | 01:39 PM
'90crxSI's Avatar
Default Re: Timing belt question (dr_latino999)
Thanks for the reply! The guy at autozone said that the water pump is the same for both series....I had him double check to make sure...I'll compare the old with the new one I have as well just to be sure. And thanks for confirming what I thought about the timing belt...looks like I need to go and purchase the correct one now.
jtwoj1
Jun 5, 2015 08:24 PM
dookeye
Dec 27, 2008 09:06 AM
Jeffrey9
Aug 6, 2008 02:33 PM
Ritchie
Feb 5, 2007 08:06 PM
