K/B/D Series garage sale...
On the stuff with no price, if you want to come pick it up, it's free
B Series:
VSS - $20
B16 Half Shaft - $30
B16 Exhaust Manifold - $30
AC Tensoner & Pulley
P/S Bracket
EJ6 Shift Boot
EJ8 Rear Tail Lights - $10
Heat Sheild
Crank Pulley
GSR Driver 3 Hole Engine Mount Bracket - $10
B16 Driver 2 Hole Engine Mount Bracket -$10
Timing Covers - $5 each
A Couple Fans - $5 each
K Series:
Heat Shield - $5
Brand New Tensioner - $40
Plug Cover - $5
P/S Pump - $30
Rear Bracket - $10
Trans Bracket - $10
D Series:
I have a D15B parts motor that had 200,000 miles on it, and was running fine when we pulled it. It has the vtec sol, rail, injectors, clutch and flywheel, alt, IM, EM, linkage, pretty much everything minus a oil temp sensor and a coolant sensor. $80
B Series:
VSS - $20
P/S Bracket
EJ6 Shift Boot
Heat Sheild
Crank Pulley
K Series:
Heat Shield - $5
Plug Cover - $5
P/S Pump - $30
Rear Bracket - $10
Trans Bracket - $10
D Series:
bradabu
Sep 2, 2011 10:16 AM
supra-n-civic
Apr 22, 2009 04:53 PM
