open tial 38mm WG with 7psi spring, boostin 10psi??
Old Sep 21, 2006 | 10:58 AM
DrivinVtec's Avatar
Default open tial 38mm WG with 7psi spring, boostin 10psi??
I have a 7psi spring in my WG. when i was running stock exhaust it would hit 7psi fine. well now i got 3in straight back. no cat/no resinators/no muffler. it jumps to 10psi almost all the time. i dont want that. its a H series an im not trying to blow it right now. do i need to restrict the exhaust some to bring it down?? i dont know if i want to do that.
comments
-George
Old Sep 21, 2006 | 11:50 AM
DrivinVtec's Avatar
anyione
Old Sep 21, 2006 | 12:07 PM
Running925's Avatar
Default Re: (DrivinVtec)
what turbo manifold are you running & where is your vacume source located for your wastegate?
Old Sep 21, 2006 | 12:19 PM
DrivinVtec's Avatar
Default Re: (Running925)
-t3/t4oe 60 trim .63 ar
-hermsfab log manifold
-going from the turbo it self to the WG
Old Sep 21, 2006 | 12:43 PM
Running925's Avatar
where is the the wastegate positioned to on the manifold?
do you happen to have a picture?
You could always compensate for it by installing a lighter spring.
Old Sep 21, 2006 | 12:45 PM
DrivinVtec's Avatar
Old Sep 21, 2006 | 01:05 PM
DrivinVtec's Avatar
is that what your lookin for?
Old Sep 21, 2006 | 03:52 PM
quicksilver1689's Avatar
i ♥ snails
thats good wastegate placement. I wonder what is causing your boost creep.
Old Sep 21, 2006 | 03:54 PM
DrivinVtec's Avatar
Default Re: (quicksilver1689)
i dont know either. it seems like it only does it sometimes..not all the time.
Old Sep 21, 2006 | 06:13 PM
boosted60-1's Avatar
where are you getting boost reference? turbo, intake manifold, or brake booster???? for the wategate......
Old Sep 21, 2006 | 08:21 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I would guess it's mostly from your more freeflow exhaust, try a lower boost spring,
or tune it for running higher boost.
Old Sep 21, 2006 | 08:30 PM
JDMs1eeper's Avatar
Default Re: open tial 38mm WG with 7psi spring, boostin 10psi?? (DrivinVtec)
try a smaller spring, that should help open it sooner. If that doesnt prevent it from creeping, do you happen to know the size of the hole cut for the wastegate tube? I'm sure its fine but I'd check to make sure.
Old Sep 21, 2006 | 08:36 PM
JFK78's Avatar
Default Re: (boosted60-1)
Take the wastgate off and check to make sure that the hole in the manifold is enlarged to the same diameter as the elbow leading to the wastgate.
I've seen this problem before and that was the reason why. With the new 3" exhaust, it's now easier for the gases to go through the turbo, and pressure in the mani has dropped.
Old Sep 21, 2006 | 08:53 PM
JDMs1eeper's Avatar
Default Re: (JFK78)
^^ yup
Old Sep 22, 2006 | 10:51 AM
DrivinVtec's Avatar
yup..its the same size. got any other ideas?
Txdragon
Feb 24, 2018 03:03 AM
808jdm_profileEG6
Jan 27, 2007 05:16 AM
boostedf22cd5
Oct 10, 2006 09:30 PM
Nextelbuddy
Oct 13, 2003 08:14 PM
Optiks.
Dec 29, 2002 04:00 PM
