92 accord stalls on stop only!
Old Sep 21, 2006 | 10:20 AM
daughterscar's Avatar
Default 92 accord stalls on stop only!
I picked up a 92' Accord EX for my daughter. 105,000 mi.
The car sat while we replaced interior.(all New). Started driving car regularly now ran great at first, now wants to stall when you come to a stop. You could shift into nuetral to try to catch it but once you stop it will stall anyway. The local Honda guru can not diagnose or fix problem. No codes, tried every sensor, runs fine other than that. oh yeh when it stall it will start right back up no problem, no hesitation idles fine accelerates smooth, everything checks out. HELP! Spent alot of money already fixing this thing up.
Old Sep 21, 2006 | 10:54 AM
JohnD1079's Avatar
Default Re: 92 accord stalls on stop only! (daughterscar)
well first thing i would say is check all the air vacuums and make sure all the hoses are in the proper position. if nothing then it could posibly ur throtle valve(or something like that). take it out and spray it with crab cleaner. i had that problem on my nissan 240sx. get further advice tho becasue im still a Noob
Old Sep 21, 2006 | 11:17 AM
Default Re: 92 accord stalls on stop only! (JohnD1079)
thanks, tried all that, all vacuum lines are good throttle body was changed out, all sensors tested, no luck
Old Sep 21, 2006 | 01:16 PM
Perfectionist's Avatar
Seems to be a somewhat common complaint... RPMs dip to near stalling or actually stalls when coasting to a stop.
In my case, on a '90 Civic Si, it would only happen as the temp guage was comming off the cold mark until halfway to the normal temp point. I adjusted the base idle, went over everthing else, with no change. The O2 sensor did read slow and lazy though. I replaced it with an OEM sensor and the dips went away.
This may not correct your problem, but if you haven't already, check your O2 sensor.
Old Sep 22, 2006 | 04:12 AM
Default Re: 92 accord stalls on stop only! (Perfectionist)
O2 was replaced, new tested. The real bitch about this one is it runs fine on a full tank of gas, once it gets to 1/2 the problem starts, fill it up problem goes away.
Old Mar 10, 2019 | 07:33 AM
woodstock66's Avatar
1/2 tank of fuel ? does it hesitate under heavy load..ie laboring up hills... weak fuel pump..i've seen that often with tank fuel pumps
Old Mar 12, 2019 | 02:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by woodstock66
1/2 tank of fuel ? does it ...
09-22-2006
I don't think he will be responding anytime soon.
OnceIwasMuffin
May 5, 2014 09:36 AM
Jimmy21
Sep 22, 2012 03:34 PM
dfbdavid38
Jan 26, 2011 08:54 AM
1717LST
Aug 11, 2010 07:25 AM
Rep
Oct 28, 2007 04:30 PM
