Will this Fit...............
Old Sep 21, 2006 | 09:59 AM
EF9SIRJeff's Avatar
Default Will this Fit...............
i can i put a Head from a D16A6 on a D15B7 Block ????
if so would it require any modification?
and what Head gasket would i use ?
just happens to be the parts i have laying around and i need to put i different head on the D15
Old Sep 21, 2006 | 10:06 AM
nighttrain33's Avatar
Default Re: Will this Fit............... (EF9SIRJeff)
I found this page
It's a d16z6 on a d15b2. I don't know much about the d15 motors, so I don't know how closely related the b2 and the b7 are, so I can't help you there. If you search mini me archived in '92-00 Civic/Del Sol, you'll get about 250 threads. This was just the second one I found.
-Shane
Modified by nighttrain33 at 12:02 PM 9/21/2006
Old Sep 21, 2006 | 10:08 AM
Actually, according to other threads that i have read while searching, it looks like there are some other ones that do use the b7 block with the z6 head.
-Shane
Old Sep 21, 2006 | 10:33 AM
EF9SIRJeff's Avatar
Default Re: Will this Fit............... (nighttrain33)
Bump
A6 head B7 Block
not Z6 head B2 Block
Old Sep 21, 2006 | 10:39 AM
All right. Apparently according to Bauley here, the a6 head is identical to the b7, so everything should just bolt right up.
-Shane
Monkeyz1
Dec 13, 2008 10:07 AM
Clifftiong
Jan 20, 2007 05:41 AM
BoostdRex
Nov 12, 2005 02:10 PM
enabi
Jul 24, 2002 07:11 PM
