Compression numbers on your Low compression set ups.
Old Sep 21, 2006 | 08:46 AM
user 98292739's Avatar
Default Compression numbers on your Low compression set ups.
So i just did a compression test with motor warm/hot
220-240-230-240
now i have 9:1 cp pistons, zex stage 3 cams, rev hard valves, isky valve springs/retainers, 3 angle valve job, PnP head
i believe i have a blown headgasket as sometimes when i start up a puff of smoke comes out. I am losing little coolant somewhere. I smell it on start up.
anyways i was wondering if those numbers are remotely right. when ih ad a 10:1 compression i only had about 210-220 compression. How am i getting such a higher compression numbers with a lower compression set up? with 240 i would think i have a high 10 ratio.
what do you guys have?
Old Sep 21, 2006 | 09:31 AM
99B16Si's Avatar
i get 180-185 with my 8.8:1 motor
there will be a small variance across different compression testers
Old Sep 21, 2006 | 09:44 AM
Boosted Chemist's Avatar
Default Re: (99B16Si)
185 across the board cp 9:1 and supertech flat valves and milled head and decked block with the sleaves install so im figureing around 9.2:1? who knows.
Old Sep 21, 2006 | 10:11 AM
fjt's Avatar
fjt
8.5:1 CR..cold engine.. 165PSI on all 4
Old Sep 21, 2006 | 10:14 AM
so wtf is up with my motor! why am i pulling 240 psi on some cylinders for a 9:1 compression motor.
Old Sep 21, 2006 | 10:33 AM
SFlCrx's Avatar
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">so wtf is up with my motor! why am i pulling 240 psi on some cylinders for a 9:1 compression motor.</TD></TR></TABLE>
it also depends on how many times you turn in over. Also if you have any oil or maybe even coolant in the cylinder when you do the test it will up you compression. do a wet compression test pour a cap of oil in each cylinder when you do it should jump up 20-40 psi unless there was oil in there already
Old Sep 21, 2006 | 10:59 AM
Default Re: (SFlCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx &raquo;</TD></TR><TR><TD CLASS="quote">
it also depends on how many times you turn in over. Also if you have any oil or maybe even coolant in the cylinder when you do the test it will up you compression. do a wet compression test pour a cap of oil in each cylinder when you do it should jump up 20-40 psi unless there was oil in there already </TD></TR></TABLE>
i turned each one over 10 times
what does it prove if i do wet compression test? and ill hit 260 psi.
Old Sep 21, 2006 | 11:35 AM
urbansi's Avatar
what does it prove if i do wet compression test? and ill hit 260 psi. </TD></TR></TABLE>
If you do a wet compression test and the numbers go up that much it points to a ring problem, but with that high of numbers in the first place i wouldnt worry about it at all. Dont people usually only crank the car over like 5-6 times?
Old Sep 21, 2006 | 11:39 AM
maybe you have massive amounts of carbon build up?
Old Sep 21, 2006 | 11:56 AM
B18 CYA's Avatar
doesn't matter exactly how many times you crank it over. Just crank it over until the compression on the guage doesn't get any higher. On my 8.2:1 motor i get roughly 165 across the board
Old Sep 21, 2006 | 12:21 PM
rebo0t's Avatar
on my 9:1 i get 165 across... something wrong? motor has 280 miles currently. did a fast break in
Old Sep 21, 2006 | 11:36 PM
rebo0t's Avatar
Old Sep 21, 2006 | 11:42 PM
B18 CYA's Avatar
Default Re: (rebo0t)
well it is also going to depend on other things not just the compression of your pistons.
milled head?
headgasket thickness?
flat valves?
etc.
Old Sep 22, 2006 | 03:23 AM
g2turbo's Avatar
Default Re: (B18 CYA)
9:1 .... 180psi accross the board after about 50 miles on the motor. I have yet to check again recently with 500-600 miles now. Probably about the same.
Old Sep 22, 2006 | 03:30 AM
Jay_Sensing's Avatar
Compression testers are not calibrated so you really can't compare what one will read to the other. I have two and there is a 30 psi difference between the two of them and they are both the same brand.
The difference between the cylinders is where you need to look and your's are pretty close so I wouldn't stress.
Old Sep 22, 2006 | 08:29 AM
ill redo it with another tester.
motor was built 900 miles ago.
im sorta stressed cause i dont want to blow my motor when i go get it turboed and tuned.
240 is just way to high for a low comp motor. but as i said agian im do another test with another tester just to make sure.
Old Sep 22, 2006 | 02:38 PM
rebo0t's Avatar
my head was milled but i compensated with a cometic .49 gasket, skunk2 non-flat valves, ported head, ctr cams... i believe the pistons are actually 9.2. maybe its my compression tester? hmmmmm
Old Sep 22, 2006 | 05:26 PM
joppe's Avatar
~8:1 dohc zc and 160psi in all cylinders.
Old Sep 22, 2006 | 05:45 PM
adseguy's Avatar
Default Re: (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">Compression testers are not calibrated so you really can't compare what one will read to the other. I have two and there is a 30 psi difference between the two of them and they are both the same brand.
The difference between the cylinders is where you need to look and your's are pretty close so I wouldn't stress.</TD></TR></TABLE>
I always stress that. Mine has read low from day 1, no problem the numbers are always consistant
Old Sep 22, 2006 | 06:19 PM
Dr. D-Series's Avatar
7.5:1 D15.
150 across cold.
gc8dc95
Feb 16, 2009 04:29 PM
soon2bdropped
Oct 3, 2007 06:28 PM
zoom545
Nov 22, 2005 09:04 AM
K20 EG
Jun 17, 2003 11:26 AM
