main relay vibrating, no fuel pump prime, no start
Old Sep 21, 2006 | 08:42 AM
ragethemachine86's Avatar
Default main relay vibrating, no fuel pump prime, no start
I've spent the last couple of days in my garage installing a new clutch and flywheel. Put everything back together and car wouldnt start. Immediately noticed the fuel pump wasnt priming. Also heard a weird noise from under the dash. It was coming from the main relay, think of the static sound ur speakers make when u are about to receive a phone call. When i touched it i noticed it was vibrating, the way a phone would. I swapped the relay for a different one and still nothing.
Any idea how installing a clutch gave me this problem? I'm freakin out cuz i have no ride to work tomorrow!
Old Sep 21, 2006 | 09:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: main relay vibrating, no fuel pump prime, no start (ragethemachine86)
Installing a clutch and flywheel should not have any effect on the "PGM-FI Main Relay", a "buzzing" relay indicates a bad relay, poor ground or poor power.
You have an IM. 94
Old Sep 21, 2006 | 03:06 PM
Default Re: main relay vibrating, no fuel pump prime, no start (fcm)
can u point me in the direction reagarding the location of the transmission ground? wont have much time to get under the car and look for it after work
Old Sep 22, 2006 | 07:39 AM
fcm's Avatar
fcm
Old Fart
Sorry not sure on a lude but on my 94 LS and every other Honda/Acura I can think of it is on top of the tranny, [close to the motor] on my 94 it is bolted to a bracket that is bolted to the top of the tranny, the bracket also holds a plastic "clip" that holds one of the rad hoses.
FSK1460
Sep 29, 2010 01:00 PM
oakpwr
10
Jan 18, 2007 09:18 PM
ragethemachine86
Sep 21, 2006 11:08 AM
uszcrx
24
Sep 9, 2006 01:05 PM
wambus
Feb 12, 2004 08:40 PM
