A6 Block, Y8 Head, WHAT HEADSTUDS?
Well i assumed y8 because i wanted to match the studs to the head. Well the y8 studs are WAY too short.
So what headstuds are you running on your mini me with an A6 block and a y8 head.
I havent found any part numbers for ARP A6 studs, im guessing i have to go with Z6?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">Well i assumed y8 because i wanted to match the studs to the head. Well the y8 studs are WAY too short.
I havent found any part numbers for ARP A6 studs, im guessing i have to go with Z6?</TD></TR></TABLE>
someone correct me if im wrong but im almost positive that the A6 and Z6 are the same length. i used the z6 in my a6 when i did a mini me. i would suggest either getting ARP or gettting brand new ones from the factory b/c the stock ones stretch and the gasket will leak.
A6 = Z6 when it comes to ARP headstuds
And I believe you need to have two Y8 headstuds when mounting the Y8 head on an A6/Z6 block, I just don't know where those two would be at since I've never tried it.
socialburn0035
Jul 24, 2008 03:14 PM
MooreBoost
Dec 8, 2004 06:50 PM
Cruiser G
Feb 6, 2004 11:26 AM
