92 Accord will not spark?
Old Sep 20, 2006 | 10:41 PM
david0286314's Avatar
Default 92 Accord will not spark?
Ok yesterday i was at the gas pump and filled up my car,well when i was done i got back into the car and it wouldnt start..so when i got it toed home first thing i checked for was to see if it had any spark. well it had none and its not the spark plugs i changed them a week ago.i think it could be a cap or rotor i dont know... or coil i have no clue PLEASE HELP!!!
Old Sep 20, 2006 | 11:49 PM
iam7head's Avatar
Default Re: 92 Accord will not spark? (david0286314)
take off the cap and see if you have heavy carbon build up(lead pencil shaving particle)
and make sure the power lead on the dizzy is plugged in, i think the older honda do have an extra wires(at least they do on my v6)
Old Sep 21, 2006 | 08:52 AM
Megamile's Avatar
Check the ignition amplifier (called igniter by most places) inside the distributor. Procedure in the Chilton & Haynes manuals.
Cost about $50.00 readily available at parts stores. If you change it, make drawing of the 4 colored wires so you know which pins they go on. The manual I had was unclear. I repaired one connector & was unsure which went where.
Noo_Ish_mee
Jun 27, 2016 02:44 PM
white accordom
Apr 29, 2013 06:08 PM
brytp16
Jan 18, 2012 11:31 AM
kenwolf
Nov 21, 2010 02:06 PM
Slink_Kardia
Mar 17, 2002 05:25 PM
