turbo lude wont run right after fueling up!
Old Sep 20, 2006 | 09:57 PM
HondaPH22's Avatar
Default turbo lude wont run right after fueling up!
I just had my car dyno tuned and it runs great until you get gas then the idle is like real low and it cuts off and wont run, you have to rev it up a few times and take off and once you get going its fine and runs good there after until you get gas again, they told me to unhook the purge valve and the e-vap hose, i think that is the one going into the throttle body. It must be pressure up or something..anyone know anything about this or where the purge valve or evap is located on the car?? 01 h22 lude
Old Sep 21, 2006 | 11:45 AM
Sick Shift's Avatar
Default Re: turbo lude wont run right after fueling up! (HondaPH22)
Timing.
Old Sep 21, 2006 | 12:51 PM
wachter's Avatar
Default Re: turbo lude wont run right after fueling up! (Sick Shift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick Shift &raquo;</TD></TR><TR><TD CLASS="quote">
Timing.</TD></TR></TABLE>
No doubt about it.
Old Sep 21, 2006 | 02:14 PM
HondaPH22's Avatar
Timing??
Old Sep 21, 2006 | 02:25 PM
cparreno's Avatar
Have you checked your timing while idle? I would def check your idle components. What kind of ecu are you using, and did you have any problems before you got tuned.
Old Sep 21, 2006 | 07:35 PM
HondaPH22's Avatar
Default Re: (cparreno)
i upgraded from a emanage to a hondata s300 was fine until tuned runs great EXCEPT after you get gas, the tuners said to unhook the e vap purge valve
JasonST
Apr 8, 2012 11:52 PM
ken2830
Oct 28, 2008 07:24 PM
Swift9
May 29, 2006 06:49 PM
navin
Aug 5, 2004 09:23 AM
dpine
Apr 11, 2004 02:18 PM
