h22 SH head vs H22a head?
are there any differences? Im looking for a h22 head, the one i found is from a h22 SH 1997. I would be putting it on a 92 h22a block w/ odb1. Are they identical?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">SH has slightly bigger cams
not as big as type S though</TD></TR></TABLE>
do you have measurements of this or is that something you read over the internet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">do you have measurements of this or is that something you read over the internet?</TD></TR></TABLE>
I have the engine specs out of the manual. give me a sec and I'll have them posted.
Guest
Posts: n/a
http://[img]https://i90.photobucket.....jpg[/img]
According to that spec sheet the mid heights are slightly larger on both the intake and exhaust cams, but according to part numbers only the intake cam is different and only between the 4th and 5th gens. According to the part numbers all the exhaust cams are the same.
That was according to http://www.slhondaparts.com/
Now according to
https://honda-tech.com/zeromodi...35439
The 5th gens are all the same but the 4th gens intake and exhaust are different
Very Strange
Modified by MadCityLude at 12:15 PM 9/21/2006
Now according to
Very Strange
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">
Very strange.</TD></TR></TABLE>
I thought the same thing
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">atts robs a bit of power....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">I think to compensate for the weight difference between the SH and base model? I dunno just a idea.</TD></TR></TABLE>
I suppose, so if someone was to want to use the SH cams they would have to swap the valvetrain also? Might as well just do a complete head swap.
what a pile of re-engineering to do just for a small gain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">btw, thanks for posting that sheet tactical customs.</TD></TR></TABLE>
for sure
for sure
that is kinda weird. You should call honda and reference the part numbers and then ask them about the numbers on the spec sheet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">So now the eternal question,
Why no change in part numbers???</TD></TR></TABLE>
All the info you're looking for is already in the FAQ, under "5th gens - Base vs SH".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porkchop »</TD></TR><TR><TD CLASS="quote">cams are different to make up for lost power from ATTS.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_LudeSH »</TD></TR><TR><TD CLASS="quote">The cam lobs do differ some as well. The reason the cams are the same part number is for ease of ordering. They have sub sections to the part number when you are ordering them. I worked in the parts department of a Honda dealer for a few montha an they are different.
As well as the factory service manual points out that they are infact different. </TD></TR></TABLE>
Guest
Posts: n/a
https://honda-tech.com/zerothread?id=762014
Still doesn't make any sence why they didn't change the part number.
