distributer wiring. help
k guys i searched this and i have no idea what is what still..
i have a 1990 dx that i've done the mpfi swap to with a complete b18a, intake and tranny. now the problem is, i have to wire in the b18a obd0 dizzy into the mix. does anyone know which wires i need to switch, or have a wiring diagram for the old dx dizzy and for the 1990 integra rs dizzy wiring. plz help guys, this biach is ready to fire, i just need to finish the wiring :D
much apreciated
josh
much apreciated
josh
the wiring location should be the same between the two...the only thing you need to do is run the wires from c1 and c2 to the wires on the dizzy...if someone has repinned the dizzy,just repin it to match the colors on the engine harness
ok so the stock b18a distributor has the same wiring colors? i'm just finishing up the dpfi to mpfi wiring conversion, and i need to know which wires do what, and which wires go where for the integra b18a1 obd0 dizzy. i don't even know what to connect the c1 c2 to..
i don't have any clue on the wiring for the teg dizzy or the 1990 dx dizzy
Help?
Bump?
Help?
Bump?
congrats.. so now i have information that does me no good, cause i already wired the mpfi, and i have two different dizzy's, one that plugs into the harness (dx) and one that has a completely different plug, but is ment for the b18a. so i ask again, straight foward, does anyone know what wires are for what on the b18a dizzy, so that i can wire in a plug and be on my merry way?
i know your trying to help, and im sorry if im being an *** about it, but i've posted this on at least 4 forums now, and i've been either directed to 4thgen's dpfi to mpfi wiring, or to hybrid garage, when all i need is the coresponding colors and use for the wires on the b18 dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh807 »</TD></TR><TR><TD CLASS="quote">congrats.. so now i have information that does me no good, cause i already wired the mpfi, and i have two different dizzy's, one that plugs into the harness (dx) and one that has a completely different plug, but is ment for the b18a. so i ask again, straight foward, does anyone know what wires are for what on the b18a dizzy, so that i can wire in a plug and be on my merry way?
i know your trying to help, and im sorry if im being an *** about it, but i've posted this on at least 4 forums now, and i've been either directed to 4thgen's dpfi to mpfi wiring, or to hybrid garage, when all i need is the coresponding colors and use for the wires on the b18 dizzy</TD></TR></TABLE>
so why dont you repin the dx connector for the b18 dizzy?
just match the wire colors from the dizzy to the harness...its really not that hard of your not colorblind...
BTW did you ever try searching for diagrams??? oh you didnt? well if you did you would have found all the info you needed...how do i know that? cuz i had to make a dizzy subharness for my car and i found all the info on here
geoff19crx
May 31, 2003 08:19 AM
