p30 vs stock ls oil pump????
Old Sep 20, 2006 | 04:56 PM
the.hamburglar's Avatar
Default p30 vs stock ls oil pump????
what is the difference in them? i have the p30 now on my ls but i think its leaking somewhere so im thinking about throwing the stock ls oil pump back on.
Old Sep 20, 2006 | 05:27 PM
one slow coupe's Avatar
Default Re: p30 vs stock ls oil pump???? (the.hamburglar)
I dont think the ls pump suplys as much oil pressure due to the non vtec..
not 100% possitive but it will still work.
Old Sep 20, 2006 | 05:32 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference in them? i have the p30 now on my ls but i think its leaking somewhere so im thinking about throwing the stock ls oil pump back on.</TD></TR></TABLE>
Why did you put the GSR/Type R pump on in the first place? Are you revving higher? Do you have VTAK?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_b16a2 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think the ls pump suplys as much oil pressure due to the non vtec..
I do think you are right about the pressure being higher.
Old Sep 20, 2006 | 05:43 PM
Default Re: p30 vs stock ls oil pump???? (adseguy)
ls vtec turbo. reving to 8k. can i still use the ls pump?
Old Sep 21, 2006 | 08:52 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ls vtec turbo. reving to 8k. can i still use the ls pump?</TD></TR></TABLE>
nope, gotta use the higher pressure GSR/typeR pump. Don't be stupid
Old Sep 21, 2006 | 10:59 AM
think i found the leak. it was from the 12 or 14mm allen bolt above the oil pump. when i built the motor i must not have reefed on it because oil was clearly coming out there and then leaking down the block and to my pan. could see it because the timing belt cover and axles were on before
Old Sep 21, 2006 | 02:24 PM
yeah but id like to know wher the difference is? more fins or what? what makes it provide more oil pressure
Old Sep 21, 2006 | 06:36 PM
adseguy's Avatar
Well I know you need a different timing belt for the differnt water pump. I've never taken a close look at both of them but I would say probably larger "fins" and provide extra flow in the higher rpms
Old Sep 21, 2006 | 07:28 PM
hmm, i thoght they were both 22t.
Old Sep 22, 2006 | 07:51 AM
adseguy's Avatar
They probably are the same teeth. I'm talking about the internals of the pump itself is different.
Jdmb16sir2
Jan 29, 2006 12:43 PM
CaptainMorgan
Oct 9, 2005 09:30 AM
RC000E
Nov 29, 2004 10:35 AM
1bar
Jun 3, 2004 10:31 PM
civictypenos
Sep 1, 2003 08:58 AM
