5 Gear Grind
Old Sep 20, 2006 | 03:13 PM
GReddy212's Avatar
Default 5 Gear Grind
My 97 prelude grinds as it is shifted into 5th gear. If i double clutch it and do it slower then usual it is fine.. any help?
Old Sep 20, 2006 | 03:17 PM
honda_andy's Avatar
a lot of 5th gens have this problem, use the search cuz its been covered a bunch of times.
Old Sep 20, 2006 | 03:21 PM
ryanjusmc's Avatar
Default Re: 5 Gear Grind (GReddy212)
ive seen a lot of transmissions do this. Most of the time its because of the synchronizers inside the transmission on the 5th and revers plentum, being out of adjustment, or just weak. The only advice i could give is to have it rebuilt soon befor it gets too bad.
91preyludesi's Avatar
you can try using syncromesh sometimes it works sometimes it doesnt. it didnt really help mine unfortunately. honda has tsb for the 5th gear synchros
Old Sep 20, 2006 | 03:30 PM
v4lu3s's Avatar
RTFM
search for the TSB about the bent/defective 5th gear fork. Honda knows about it...
Old Sep 25, 2006 | 08:00 PM
bbking790's Avatar
I thot the syncros stopped after 3rd gear.
And btw - my forth gen sometimes has the
same problems with 5th grinding except when
i double clutch or change in sloww
Old Sep 25, 2006 | 08:05 PM
JasonST's Avatar
Default Re: (bbking790)
I'm pretty sure 4th and 5th have synchros too, or else u'd have to rev match.
Old Sep 26, 2006 | 06:02 AM
syshs's Avatar
Default Re: (JasonST)
^^ +1
SoCalian_SD
Jan 18, 2009 07:43 AM
94jdmlude
Dec 30, 2008 02:38 PM
tegG2
Honda Motorcycles
Aug 21, 2005 01:08 PM
bseries_beast
Jun 6, 2005 09:33 PM
