wheels question
Old Sep 20, 2006 | 01:08 PM
EJ8CIVIC's Avatar
Default wheels question
i just wourdernig what other import rims will fit my honda (96-98 civic)
or what other 4x100 bolt pattern cars will work??? better question
Old Sep 20, 2006 | 02:26 PM
peacexisxfree's Avatar
Default Re: wheels question (im napoleon)
any rim with a 4x100 bolt pattern and proper offset will fit.
Old Sep 20, 2006 | 02:54 PM
old man neri's Avatar
Default Re: wheels question (peacexisxfree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">any rim with a 4x100 bolt pattern and proper offset will fit.</TD></TR></TABLE>
Not entirely true.....don't forget about the bore/hub size. 56.1mm on your civic I believe. So a VW rim's bore will be too big and a miata rim will have a bore that is too small.....etc
Old Sep 20, 2006 | 03:11 PM
Leo C's Avatar
Night Owl
Some OEM wheels to look out for:
92-93 GSR wheels 14"
Del Sol Si/ Vtec rims 14"
94-95 GSR/SE fat fives 15"
97 GSR/ 98+ LS meshies 15"
96 GSR/SE starfish wheels 15"
98+ GSR blades 15"
99-00/ 02+ "Si wheels" 15"
Any OEM optional wheel for a Civic/ Integra should also work. Do not buy any Accord/Prelude wheels as these are 4x114.3 and will not fit.
Old Sep 20, 2006 | 03:53 PM
Default Re: wheels question (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Not entirely true.....don't forget about the bore/hub size. 56.1mm on your civic I believe. So a VW rim's bore will be too big and a miata rim will have a bore that is too small.....etc</TD></TR></TABLE>
well, yes. but, you can always get hubcentric rings...except for a bore that is too small.
no biggie.
i am dealing with a wheel that has a larger bore than my hub righ tnow, so i need hubcentric rings...
JeromeFit
Honda Fit
Mar 27, 2007 03:21 PM
CsRiX
Jan 14, 2004 10:48 AM
NOSpeed97
Jun 9, 2003 10:28 AM
HeelToe
Jan 31, 2003 07:26 AM
