Bseries drag tranny?
Old Sep 20, 2006 | 12:13 PM
itr_18's Avatar
Default Bseries drag tranny?
Hi,
do you know any company that makes trannys for Bseries which let me finish on 3rd gear? Or maybe veeery long 1st and 2nd gears for Bseries? Something longer than ATS 3.077?
Thanks!
Old Sep 20, 2006 | 03:42 PM
FMUNK's Avatar
Default Re: Bseries drag tranny? (itr_18)
Libertys Gears could do some crazy ratio's if you feel you need them.
http://www.libertysgears.com
Give them a call and ask.
Old Sep 20, 2006 | 03:44 PM
vtecmissle's Avatar
if you only need 3 gear these could probably be built up to a thicker gear and you could still run a cradle.
Old Sep 21, 2006 | 12:49 AM
itr_18's Avatar
Thx, im looking for very long 1st and 2nd gears - much longer than ATS 3.077 1st - do you know if anyone else might make 1st and 2nd custom gears for b-tranny?
Old Sep 21, 2006 | 07:42 AM
AutotechRD's Avatar
Default Re: (itr_18)
Try http://www.quaife.co.uk.
Old Sep 21, 2006 | 08:04 AM
tony1's Avatar
Why would you want very long gears?
Old Sep 21, 2006 | 08:48 AM
MAX_CFM's Avatar
Default Re: (tony1)
Just out a power glide in it
Old Sep 21, 2006 | 09:16 AM
BLK JDM's Avatar
Default Re: (MAX_CFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">Just out a power glide in it </TD></TR></TABLE>
Now that's funny!!!
Old Sep 21, 2006 | 10:47 AM
itr_18's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want very long gears?</TD></TR></TABLE>
PM'd you
Old Sep 21, 2006 | 10:52 AM
itr_18's Avatar
problem is in my 60ft times - aprox 2.6.
Ive gt35/40r and autronic standalone ecu. We cant get enough low boost on 1st and 2nd gears. Even on 9x26 tires, wheels spin. Any ideas? TIP: We have no vht, just "regular" airport tracks.
Old Sep 21, 2006 | 11:35 AM
DaveF's Avatar
do you have.........
traction bars ?
LSD ?
good suspension?
low air pressure in your slicks ?
boost control ?
Old Sep 21, 2006 | 11:39 AM
itr_18's Avatar
Default Re: (dturbocivic)
Im not an idiot
Lcon tra bars, circuitworx drag spool, drag launch kit, low air in 26x8.5 and boost control
Problem is in making lower boost - we can change it but we cant make it lower than 12 psi. And its hard not to spin on track with weak grip with no bht
Old Sep 21, 2006 | 08:55 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">Im not an idiot
Problem is in making lower boost - we can change it but we cant make it lower than 12 psi. And its hard not to spin on track with weak grip with no bht</TD></TR></TABLE>
Don't you know the taller the gears the more it will spin. If you don't want to make boost then don't load it so hard go the otherway.Run a real low 1st and don't short shift it.That will get you rolling without loading it so hard.And use a 2nd gear that is close to your first gear .By the time you get in 3rd then you can use a taller gear to load it harder and use the boost and the power that goes with it.
Or do like Brad says get a glide...LOL
Old Sep 22, 2006 | 12:14 AM
itr_18's Avatar
Default Re: (RMF)
It looks like a good idea, we'll make more test. Sorry for "maybe stupid questions" bu drag racing is very new in Poland and because of bad grip everybody makes fast AWD cars and no experience in fast fwd/rwd cars.
Old Sep 22, 2006 | 12:43 AM
IT'S ME DAVID's Avatar
NooB
go allmotor problem solved.
Will_H
Transmission & Drivetrain
Nov 8, 2010 03:14 PM
hmoobhero
Aug 5, 2009 06:19 AM
IN VTEC
Jan 4, 2009 02:05 PM
