D16y8 running no cat with 2.5"catback
Old Sep 20, 2006 | 11:07 AM
1q2w3e4r5t's Avatar
Default D16y8 running no cat with 2.5"catback
Is it safe to run a D16Y8 with a busted out cat? Ive got a 00 civic ex with a AEM v2 CAI,DC sports 421 header,busted cat, and 2.5inch catback exhaust? I had JET custom tune my ECU for the modifications i have listed but my check engine light is constantly on? Is it safe to run it like this or is this bad for my engine. I know DOHC run well without a cat but i wasnt sure if the SOHC did as well. Thanks
Old Sep 20, 2006 | 11:29 AM
sicones's Avatar
Default Re: D16y8 running no cat with 2.5"catback (1q2w3e4r5t)
you should put a cat back on, high flow or stock, you will lose a lot of low end torque and you car will sound and smell like ****, it will also get rid of your check engine light
Old Sep 20, 2006 | 11:30 AM
Ghetto Civic HX's Avatar
I love to drive
You should be fine. That CEL is because the second o2 sensor isn't getting the proper readings. But your A/F ratio should be okay.
Get an OBD reader and make sure that's the only CEL you're throwing. You can get an o2 sim to clear that CEL, because if another problem comes up that would throw a CEL, you wouldn't know.
Or just replace the cat.
Old Sep 20, 2006 | 12:25 PM
wakeboard_dude5's Avatar
you're gunna be runnin rich until you fix that CEL. Do motha earth a favor and just put in a real high flow cat, not an imitation test pipe! you only have a D series, you'll need all the torque you can get! With that i'd also step down to a 2 1/4 exhaust but if you have 2.5 just keep it on.
Glenlivet12
Jan 14, 2013 04:56 PM
dac55
Jul 19, 2011 07:23 AM
itr1244
Aug 26, 2004 07:46 PM
ajchen
Mar 26, 2003 08:23 AM
paulyman
Jan 21, 2002 02:49 PM
